A friend was at my home dog sitting while I was at the hospital with my husband who had recent open heart surgery. She signed the contract and gave him half the money up front. He's always got an excuse as to why he can't cut it down. There's no address on the contract just a phone number. He took advantage of my 73 year old friend who thought it would be okay to give him the money.
SOURCE: Motorola Motorokr Z6M will not turn on
Hello everyone, I also have the same phone, and the same is happening to me, I've changed the phone 4 times in less than 3 months (Metro PCS carrier). My 16-year-old brother had almost the same problem with his RAZR 2 years ago, but he knew ho to fix it, so I gave him my phone everytime it freezed up. It seems the only way to fix this is:
take out memory card (if applicable)
take out the battery and put it on constantly.
If it doesn't work leave it charging for at least 1 hr. Then do all over again
you have to be real patient, it will take a while till it actually comes on.
UPDATE: I just fix my 4 and last phone, as of yesterday, while my cell was broken I switched to Sprint, and got me the new Samgsung Instinct S30
Motorola R.I.P
SOURCE: siverado truck makes noise from transfer case
possible actuator in the transfer case. but the whine is a indication that the gears maybe failing. find a junk yard transfer case and change out
SOURCE: 2006 Nissan Sentra SE w/ transmission problems
Where is your reverse located? from you description, I'm guessing it's next to 1st. It sounds like you may have a bad linkage or the knob is off. You should be able to adjust this under the car. You'll see a cable running from the gearbox to the transmission...
SOURCE: Andis pm-3 dog clipper won't cut anymore!
I have had this same problem! I bought new blades, sharpened old ones, and nothing worked. Finally, I went to an authorized service center and they couldn't figure it out. Then the tech. pressed on the blade (the outside bottom one) and it cut! When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade. One of those was not screwed in tightly. That was all it was! I guess they jiggle loose. I hope this helps!
peony
SOURCE: Boost Mobile - I465G No-Contract Mobile Phone won't start up
use this link to contact Boost Mobile either through email or phone, I recommend calling them and tell them what happen and they should send you a new phone.
here is the link:
http://support.boostmobile.com/contact_customer_care.html
The felling axe purpose is to cut across the grain of wood
as in the felling of the trees. There are different weights, shapes, handle
types and cutting geometries to match the characteristics of the material being
cut.
