Question about Pool & Spa
My Coleman lazy spa model 54131e. It just keeps flashing. The entire control panel. It's not showing a code. I opened it up and cleaned out some debris in the lines but I can't get it to do anything when I un plug it. It just flashes and beeps.
Posted by Louis ladusaw on
5 Related Answers
Anonymous
SOURCE: filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Posted on Sep 16, 2007
eagle338
eagle338
  • 4889 Answers
SOURCE: amana oven
Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Oct 17, 2007
prem mathew
  • 1294 Answers
SOURCE: LE Code on control panel
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Posted on Dec 31, 2007
Alan
  • 80 Answers
SOURCE: "Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
There are two things you can check, there is a tranformer that plugs into the main circuit board(usually a four wire plug). Unplug and check pins for good connection and then reconnect There are usually one or two fuses inside the control box mounted on or near the circuit board. Turn off power to spa and pull fuses and check continunity. This is a good start.
Posted on Aug 19, 2009
Anonymous
SOURCE: Need owners manual for coleman 455 BEACH GR spa.
Here's what worked for me
Press and hold the following three buttons in sequence: PROGRAM - MODE - SET DOWN. Once all three are being held down, the lock symbol will disappear; and the control functions are unlocked. =0 )
Posted on Aug 21, 2009
Hi everyone my coleman lazy spa leaks from pump is there a way to fix this?TIA
looks like this has a magnetic drive pump and are not common to leak. so disassemble and locate loose or cracked part and try silicone or epoxy to do the repair. I recommend Majic lube for rubber o-rings and gaskets Lay Spa Teardown
Jun 18, 2017 | Pool & Spa
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Coleman evcon four flashes on indicator...fans work... won't fire
Hi it could be the pressure switch clean the back of the fan control sensor, and the flame sencer
Feb 19, 2010 | Tools & Hardware - Others
Getting error code 188E on Jandy Model LT Lite 2 pool heater. also control panel keeps flashing. Anyone know why
press the arrow key for 10 sec this will reset the heater. if code replace control board, if not enter time date and set temptures for pool and spa
Jun 06, 2009 | Jandy Digital Lite2 Lj250 Btu Heater,...
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Pool & Spa Logo
538 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Pool and Spa Expert? Answer questions, earn points and help others
