Question about Thomson Audio Players & Recorders
I have a Thomson 6677. Have windows vista. Have dragged and dropped songs to mp player, but no sight of them on the player itself. But when I plug player into computer...songs play. please help!
Posted by Julia Pearson on
5 Related Answers
Anonymous
  • 626 Answers
SOURCE: Formated the SanDisk Sansa E280
You dragged & dropped files in recovery mode? Recovery mode is only for re-installing the firmware or formatting the device if it is unresponsive. If you are wanting to drag and drop files onto the device, the music needs to be put into the Music folder on the device. If you do not see the Music folder, you will need to enable hidden files and folders on your PC. Best of Luck. p.s. - you can add to this question this doesnt work.
Posted on Oct 08, 2007
Anonymous
  • 490 Answers
SOURCE: sony walkman nw-a3000
hi ali
it is comman problem , when u connect to pc , songs are played by song player of computer (like media player or real player) but latest version to play songs of the format is present in walkman is there, due to lac of cd's , i suggest you to please go to Sony' website and download latest software of said modle & update , it will solve the problem
thanks
Posted on Nov 13, 2007
Anonymous
SOURCE: Sansa m250 2GB file adding problems
2000+300
4000
Posted on Jul 09, 2008
Anonymous
  • 4 Answers
SOURCE: My Coby MP-705 Won't Delete Songs
I had the same problem - VERY frustrating. Just found the answer, and am very happy to share it!
1. In setting/USB mode, select MSC mode.
2. Plug in Coby to USB
3. Open My Computer. Look for the Coby as a REMOVABLE DISK, not the Coby.
Files will be there for Viewing and Deleting! (On XP, at least).
4. Make a backup of MTP.BIN and WMPInfo.xml, which I think is the operating sytem?
I got the clue from here:
http://www.fixya.com/support/t357600-problem_coby_mpc7095_2_gb_mp3_player
Paupaul
Well, turn on you mp3 player, go on setting/USB mode and select MSC mode.
Then plug it on your computer and check in MICIN.DIR folder. You must find them.
It wasn't exactly what I saw, but once I looked, it was all there. Perfect!
Posted on Mar 04, 2009
Anonymous
  • 13 Answers
SOURCE: Emerson 4GB MP3 player EMP513-4 files don't show in Windows
Not a problem. Microsoft Digital Rights Management (required by RIAA and record companies) enforces one copy per song only. Otherwise you are a pirate. Buy another copy of the song. "Arrgh, me matey," says the parrot.
Posted on Oct 15, 2009
Thomson 6677
Hello Ace,
Is it possible that you are looking in the wrong folder in the MP3 player when it's disconnected?
Kind regards,
Ron.
Mar 27, 2014 | Audio Players & Recorders
Ive got a Thomson MP3 (6677) which i still use, and a Windows 7 laptop - i see the drivers on the accompanying disc (Musicmatch Jukebox) are for Windows 98 and im worried that if i install it on this pc,...
If your mp3 player is connected via usb, it is probably supported directly by windows 7 and will be recognized as a thumb drive when you plug it in.
Feb 23, 2011 | Thomson Computers & Internet
How do you put music on the SanDisk Sansa Clip MP3 Player
1. First, you have songs saving in your computer.
2. You have 2 ways to put music on the Sandisk Sansa Clip:
2.1. Plug device into computer, Drag and Drop music from your computer into "Music" folder of the Sandisk Sansa Clip.
2.2. Use Windows Media Player in your computer to transfer songs to your device; Plug device to computer, open Windows Media Player, click on Sync tab, drag and drop music into "Drag items here " on the right side of the windows media player, click on Start Sync button.
Good luck
Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
How do I download music to my Sansa Clip MP3 Player
First, you have songs into your computer. Then, plug the device to computer and use one of two ways to download music to your Sansa Clip:
1. Select songs you want transfer, drag & drop them into Music folder in the device.
2. Use Windows Media Player: plug device to pc, open windows media player, click on Sync tab, drag and drop songs selected to Sync List space (on the right side of wmp), click on Start Sync button to transfer.
Good luck
Jan 25, 2010 | SanDisk Sansa e260 MP3 Player
Where can i download drivers for a thomson 6677
http://www.rcaaudiovideo.com/product.aspx?product=25&post=6
Nov 08, 2009 | Audio Players & Recorders
I synced music from windows media player to my coby MP-C781 MP3 player and now it wont power on. And I've tried everything
what I would do is plug it back to the computer and if that works what you should do is go to the manufactures website and download new firmware for your player and reflash the player and try draging a dropping the music instead of using windows media player. this is how you can drag and drop:
first off find where your music is stored and open up that window then open up a window with you mp3 player in it and drag and drop the music into the window with your mp3 player
Sep 29, 2009 | Coby MP-C781 MP3 Player
How do i download songs from my home computer
You can open windows media player and tranfer music from your computer to your mp3 player. If that does not work go to "my computer" and open your mp3 player and locate the music folder and drag and drop your music.
Sep 24, 2009 | Coby MP-C653 MP3 Player
Drag and drop problem
Have you over loaded the memory? I had this problem and had to erase a lot of files that I no longer use.
Rick
Jul 18, 2009 | Tascam Mp-bt1 Portable Mp3 Bass Trainer
Erasing songs from MP3 player
if you have windows media player, which i uses to drag and drops all my songs, go to the sansa player which appears on the left, click on it. It should show all your songs and mostly everything, right click on the mouse and it should show a list of which song you wants to delete.
Sep 26, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Coby MP-C883
I have been able to sync mine, though it wouldn't transfer some songs. It would sit there trying to convert it but wouldn't. So I tried the alternate way to get them on. I just did a drag and drop and all the songs played fine. I just had to be sure to hold the play/hold/stop button for about six seconds before it would turn on.
BTW all of the songs including the ones windows wanted to convert played fine this way.
May 12, 2008 | Coby MP-C883 MP3 Player
Top Thomson Audio Players & Recorders Experts
Jean Sintulaire
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
