Question about Zeiss Science & Laboratory
I have a relatively new Zeiss FDT visual field screener and sometimes patients report the screen goes black?
Posted by Kenneth Ryfkogel on
Don A
  • 2,710 Answers
1 Related Answer
Anonymous
  • 9 Answers
SOURCE: Screen goes off black...
your console might be over heated . if you continusly try to play it, stop leave it alone for around 10 minutes. get a soda watch some tv and make sure that consule is completly disconnect from the wall.
Posted on Jan 17, 2009
How do I fix the pointer on the touchscreen to be where you touch
You sjould press the patient button and the same time turn it the instrument on keep in button press until you see in tje display the calibration message of the touchscreen
Oct 03, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
CAN THE LIGHT BE TURNED ON IN THE ROOM WHERE THE TESTING IS DONE?
Yes it affect all tje instrument calibration when it is turn on, and when you have patient test the result is afected because the patien has light for the bavk and he is not able to see all the diferents type of lights
Sep 18, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
How can I fix my screen ,will not show anything on the field analyzer 740i? Help please
Did you move the brighness control. It is on the right side of the equipment. If not, it could be the video board inside of the equipment
Aug 05, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Why does my zeiss humphrey visual field machine keep shutting down?
Sounds like a heat, thermal issue. You may have a non- functioning cooling fan somewhere inside. There are several of them so don't be fooled if you hear one of them running. Same issue happens with CPUs on PC computers. Will suddenly shut off if too hot.
May 24, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Zeiss humphrey system startup state 19
I believe "state 19" is a weak main illumination bulb. Not sure if it's the same on your 740, but that's what the problem was with our 750i. Even though the bulb appears to be working, they dim over time and won't pass the start up calibration checks. On ours, there is a round access panel on top of the unit to service this bulb. Just be careful removing the bulb and don't bump any of the clear optical wheels. Part # 2660021106082 (for 750i. not sure about 740) Call Zeiss to confirm. Realize this is an old post so info is for future readers.
Mar 27, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Perimeter need frequent calibration
How can I calibrate the equipment.
Thank you
Luar G
Oct 22, 2013 | Zeiss Humphrey FDT 710 Perimeter
Science & Laboratory Logo
1,645 people viewed this question
Top Zeiss Science & Laboratory Experts
Anon
Terry
Terry
S J Parkin
S J Parkin
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
