Hello Ajay Gaddi...
Flashing panel...
I got NOTHING after reading several manuals
(seems to be a UK model... We have limited information here in the USA)...
Accept my apology and try these references
(as appropriate)
If after checking these points you still need assistance, please refer to your nearest
Fisher & Paykel Authorised Repairer, or contact us through our local website listed on the back cover.
In New Zealand if you need assistance...*
Call your Fisher & Paykel retailer who is trained to provide information on your appliance, or if we
can be of any further help, please contact our Customer Care Centre.
Toll Free: 0800 FP CARE or 0800 37 2273
Fax: (09) 273 0656
Email: [email protected]
Postal address: Fisher & Paykel Appliances Ltd, PO Box 58732, Botany, Manukau 2163, Auckland.
If you need service...*
Fisher & Paykel has a network of independent Fisher & Paykel Authorised Repairers whose fully
trained technicians can carry out any service necessary on your appliance. Your dealer or our
Customer Care Centre can recommend a Fisher & Paykel Authorised Repairer in your area.
In Australia if you need assistance...*
Call the Fisher & Paykel Customer Care Centre and talk to one of our Customer Care Consultants.
Toll Free: 1300 650 590
Fax: (07) 3826 9298
Postal address: Fisher & Paykel Appliances Ltd, P.O. Box 798, Cleveland, QLD 4163
Fisher & Paykel has a network of qualified Fisher & Paykel Authorised Repairers responsible for
servicing only Fisher & Paykel branded appliances. Our Customer Care Centre can recommend a
qualified Fisher & Paykel Authorised Repairer in your area.
In United Kingdom if you need assistance...*
Phone: (0845) 066 2200
Fax: (0845) 331 2360
Postal address: Fisher & Paykel Appliances Ltd, Maidstone Road, Kingston, Milton Keynes,
Buckinghamshire, MK10 0BD
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back
wall inside the freezer will ice up under normal conditions. Every 8 to 10
hours for around 20 minutes the defrost timer (or in most newer models the electronic
adaptive defrost control) will turn the defrost heater on to
melt the built up ice. There is a defrost thermostat which prevents the heater from
overheating the freezer by breaking the heater circuit when the temp reaches
close to 32 degrees F. The entire cooling system shuts off during the defrost
cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to
build up until the air can’t flow over the coil to circulate the cold air
through the freezer and into the fridge. The temperature change in the fridge
is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from
coming on OR it won’t turn the heater off when it gets too warm. It is clamped
to the evaporator coil at the top to sense the temp. If it appears to be
misshapen it is bad.
With an ohm meter it should show continuity when
cold and none when warm.
You can also bypass the thermostat to see if the
heater comes on then. If it does then you know the thermostat is bad and needs
replaced.
The defrost heater is
located on the evaporator. It is in a tube which is at the bottom and can also
go up the sides of the evaporator. On some types you can see a burnt spot if
it’s bad. With an ohm meter it should show continuity from end to end when
disconnected from the wiring in the freezer. You can also test the wiring for
voltage when it’s in the defrost mode.
If
you have a defrost
timer you
can test it. It can be located under the fridge behind the kick panel on the
front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts
down. The heater should now come on. If it does, replace the timer because that
means the timer is not running. If it
doesn't, check the heater and defrost thermostat. Turn the timer again till
everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer,
replace it if the heater and thermostat test good. It is located in the fridge
with the controls in some models and on the back in others.
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
SOURCE: Fisher and Paykel GW612 - Lights showing
Hi just read your posting.The fault on your machine is called Single Rotor Position Sensor Error.The rotor sensor is attached to your motor which is located underneath the machine.Now the Error Code will come up on your machine because 1--The wiring to the Rotor Sensor is faulty. 2-- The rotor sensor itself is faulty or 3--- The motor controller, 'which is located under the top panel is faulty.Unfortunately to test the rotor sensor you need an RPS tester .This device will also check the wiring to the rotor sensor.If you have an electrical test meter I can guide you throe the testing of the wires to the rotor sensor but without the RPS tester you cant accurately test the rotor sensor.Some service techs I know just change the rotor sensor to see if that rectifies the fault but in your case you dont have a rotor sensor so even if you do purchase one and change it, the fault could be your Motor Controller.My best advice to you would be to borrow an electrical test meter if you do not have one and reply back and I can help you eliminate the Wiring as the cause of the fault,and then contact a service tech to find out if the fault is with the Rotor Sensor or the Motor Controller.But if the fault is with the wiring then I can guide you throe step by step to repair it.I hope this helps and please reply on how you got on or if you need further assistance.Good luck.
