Vacuums Logo
Question about Kenmore Vacuums
We changed one section of the wand on our Kenmore model 116 vacuum cleaner and the new part doesn't make proper electrical contact to the Powermate when the wand is assembled.
I can see that the power receptacle slides up into the handle when I push the two section of the wand together. What's the best way to fix this?
Posted by Jim Newton on
Bill Gelchion
    Habit-Forming:
    New Friend:
  • Kenmore Expert
  • 101 Answers
5 Related Answers
Anonymous
  • 417 Answers
SOURCE: kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Posted on Jul 17, 2008
Anonymous
  • 3 Answers
SOURCE: Can you tell me if
i think your confusing model #s ,as the 116. 22512202 is the canister model number and the model number of the powerbrush attch would be 116.52512202,but to answer your ? no it depends on which wand your useing that determans which one you can use
there 3 types of wands 1 telescoping which comes only on progressive models 2 a 2 piece with wire connected and a 2 piece
wire not connected,hope this helps,les
Posted on Mar 05, 2009
Anonymous
SOURCE: Kenmore Model 116 PowerMate Jr stopped working
If the roller brush is not spinning freely once you remove it from the Power Mate Jr., then I have discovered the solution! There are end caps at each end of the roller brush. They seem to be permanently attached, but they are not. There is an axle inside the roller that is permanently attached to one of the caps. Take two pairs of pliers, and grab each end cap with a pair of pliers. Then pull hard to take them off. Once they are off, you will find that there is a big glob of hair wrapped around the axle inside. Remove the hair. Then reassemble the brush by putting the end caps back on. Make sure, when you put the caps back, that they are aligned so that they will fit back into the slots on the Power Mate Jr. You have to push hard to get the caps back on, maybe tapping one of them with pliers.
Posted on Mar 28, 2009
dnewcombe1
Dana Newcombe
  • 1564 Answers
SOURCE: i need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Posted on Feb 13, 2010
Anonymous
  • 438 Answers
SOURCE: Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Posted on Mar 21, 2010
3helpful
2answers
The power brush on my Kenmore canister vac #116 2761 works intermittently Depending on how I hold it. Seems to be a problem with the contacts on the wand????
all you can do is clean them contacts that you see on the wand
use wd40 .
an a brillo pad or such.
look at the female connector on the end an see if u can tighten an clean it .
2answers
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
1helpful
When using the vacuum (25812) with the powermate, the power shuts off - now it just stays off. The PM Jr. works.. could this be a problem with the wand rather than the powermate unit?
Check your lower and upper wand connects for pinkish or blackened evidence of burning. All connections should be shiny clean brass. Polish with wet dry # 600 paper or a scotch abrasive dish pad.
If the junior runs, with its tighter, cleaner less used connections it is very likely the wand connections and mating component, either the hose handle or power head elbow are also burned or badly worn. On a Kenmore, due to the weight of the head and mediocre design they wear in pairs and should be replaced in pairs. You can get some electrical parts thru a Whirlpool FSP parts center or a Panasonic dealer if you take in the matching pieces for clarification
2helpful
Can you tell me if Powermate Power Brush attachments are all the same for all the Sears Powermate Cannister vacuums.  That is, would one power brush attachment on a Model 116.56512690 fit one that is Model...
4helpful
5answers
Kenmore vacum wand power cord
Try here
Jul 16, 2008 • Vacuums
6helpful
5answers
Powermate connection flickers
I had the same problem. Sears has replacement parts for mine (Model 11625813506) here: http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11625813506&pop=flush
Rather than pay $10 for a new cover terminal (which I probably couldn't install myself anyway), $99 for a whole new wand, and possibly $108 for a whole new hose (ridiculous prices, btw), I took a small flat head screwdriver and scraped off the dirt/corrosion on the terminal pins. This didn't resolve my problem, but I noticed the connection between the extension wand and the "Power mate" hose handle was loose. The handle could wiggle/slide about 1/8" when connected to the wand, creating the loose connection. I used the screwdriver to bend the pins down slightly (in the direction away from the wand tube), to compensate for the loose connection. This worked like a charm, fixed the intermittent circuit contact completely, and was very easy to do. I'd highly recommend trying this, before doing anything more complicated.
Open Questions:
Top Kenmore Vacuums Experts
Marvin
Marvin
David Shaub
Mike
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
