Question about Electrolux Washing Machines
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Posted on Jul 22, 2008
SOURCE: AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Posted on Aug 03, 2008
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
SOURCE: how to reset my washing machine (electrolux)
my electrolux EWT606 will not spin. it drains and then just wont go into spin cycle....no error messages it just beeps. can anyone help me please as i have kids with disabilities and NEED to wash!
Posted on Sep 26, 2010
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
