Question about Mercury Boating
I HAVE NO SPARK ON 40HP MERCURY OUTBOARD MOTOR
Posted by Barbara Butler on
Steve P
  • Mercury Master
  • 3,712 Answers
Hey Barbara,, get one of these manuals,,, you will need it to trouble shoot this outboard..
Mercury Outboard Manuals by Seloc 1965 2014
Posted on Sep 23, 2017
5 Related Answers
Gene Pitts
  • 159 Answers
SOURCE: relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Posted on Oct 30, 2008
mcgyver468
Mark L. Roberts Jr.
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
Anonymous
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
Mark Chapman
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
Anonymous
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
I have a 2000 mercury 40hp outboard , does this motor have a fuse inside i can replace, no power to ignition, or tilt,
if ignition attached to a dashboard fuses in behind dash board. should be marked. if motor is tiller steering then the fuses are inline or tucked in housing. back track from problem.
Aug 26, 2017 | Mercury Boating
How do you change the park plugs in a 40hp Mercury outboard four stroke motor?
Greg, if you are puzzled about changing spark plugs.. Please take this to a shop somewhere.
May 22, 2017 | Mercury Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
I need to change the incandescence candles of my two stroke outbord motor, 40hp, about 20years old. I don't know the reference, may be NGK B7HS ?.
They are called Spark plugs.Look at the letters and numbers on the white part of the 'Spark plug'.The 1st bit are the brand,the second bit is the heat range and length of the thread of the spark plug.If the motor used to run well.Buy the same spark plug.Hope this helps you
Apr 21, 2010 | Light Outboard Motor Boat Bass Fishing...
Apr 27, 2009 | Boating
Boating Logo
1,179 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
