Question about Sony Televison & Video
Sony Bravia built in DVD player wont accept the discs - why is this?
Posted by Alix Fowler on
colinat108
    Sergeant:
  • 244 Answers
Performing a power reset
1. Turn off the television.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
How to establish an HDMI connection between a TV and other device.
Follow the steps below if the HDMI® connection between your TV and other device is not working:
1. Make sure both the TV and other device are turned on.
2. While turned on, unplug the power cords for the TV and device from the electrical outlet.
3. Disconnect the HDMI cables from the TV and other product.
4. Wait 60 seconds.
5. While the HDMI cables are disconnected, plug the power cords back into the electrical outlet.
6. Turn on the TV.
7. Re-connect the HDMI cables.
8. Turn on the HDMI-connected product.
The TV should now detect the HDMI signal from the connected device and operate normally. If there is still a problem, disconnect the HDMI cable from both products and then reconnect it in the opposite direction. In some situations this has been reported to resolve connection issues.
How to reset a TV to factory settings: https://us.en.kb.sony.com/app/answers/detail/a_id/61396
Hopefully this post helps you! If does, please mark it "accept as solution"
Posted on Sep 06, 2017
5 Related Answers
james klgr
james kilgore
  • 362 Answers
SOURCE: dvd player will not open
look at the bottom of the unit and see if it has a slot to put in a pin and manually open the drive, most of them have some way to do this look for a slot or pin hole to push the release, sometimes they do this because someone pushes the drawer closed instead of using the button or remote, you will have to open it to reset it if that is the case you might have to easily force it open.
Posted on Dec 24, 2007
Anonymous
  • 14 Answers
SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Posted on Mar 02, 2008
Anonymous
SOURCE: sony bravia lcd hd flat screen tv
scratches on panel of 52 inch Sony LCD
Posted on Apr 15, 2008
Anonymous
SOURCE: Sony Bravia with Phillps dvd player
It's not compatible with the Phillips DVD player. We had the same problem with our old DVD player, something about reading it.
Posted on Oct 19, 2008
Anonymous
SOURCE: Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Posted on Aug 20, 2009
I have dvd sony dvp ns575p it'work but can't red dvd disc and i change the linces
you must read your instruc. manual for to see what format accept your DVD. Not all the DVD accept all format, download the instr.manual go www.fitness.manualsonline.com or www. retrevo.com and proceed according.
However you must shure that must clean the OPU with special DVD cleaner, you can get in Radio Shack or other store electronic supplies. clean it . is a GOOD IDEA, and maybe fix your problem.
God bless you
Jul 11, 2012 | Sony DVP-NS575P DVD Player
My sony dvd oplayer/recorder only sometimes accepts the dvd-rw discs without displaying disc error
That is odd, the only other option is buy a DVD cleaning kit and follow the instructions it might solve your problem.
Mar 07, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Hi I cannot find the dvd eject button on my sony bravia. Can you please help me
All the new models of DVD player have no eject buttons. Its a safety feature to prevent the eject door from jamming or motor failing when somebody ejects the disc while the player is in a cabinet with a glass door. Also the logic is one has to approach the player to remove or insert the disc anyway !!!
May 29, 2011 | Sony Televison & Video
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
Aug 18, 2009 | Sony DVP-CX850D DVD Player
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Sony dvd wont play certain discs
yes the sony dvd players is made for certain regions it wont play other discs that are not either region one or two new zealand i think is region 3
Apr 15, 2009 | Sony Televison & Video
Dvd player won't play, sony bravia theater system, says no signal
Are you talking about the DVD player built into the HT? Make sure it's selected as the output device using the "function" buttons. The HT should say "DVD".
Dec 31, 2008 | Sony BRAVIA DAVHDX275 Theater System
I think a connectivity problem with tv and dvd player
dvd playes or hd dvd players will not play blu ray diskd you must have a blue ray player to play blu ray disks
Dec 02, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
51 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
