SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
SOURCE: nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
SOURCE: samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
SOURCE: I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
