Question about Panasonic Video Cameras
Where is the dew detection switch located on a Panasonic camcorder model PV-L550D
Posted by barry on
abdul rauf
    Dedicated:
    Visited the website for 20 consecutive days.
  • Panasonic Expert
  • 483 Answers
There is no switch on the system, in side the mechanism you can see the dew sensor LDR clean it and dry
Posted on Sep 10, 2017
3 Related Answers
Anonymous
SOURCE: Dew Detected
Hi. I've had this problem a few times myself when I was tent camping or outside for a long time.
Remove the battery, and see what happens. If it keeps happening, I let it sit out of the bag for a couple of hours in the car with the battery removed.
I would not suggest hitting the camera.
Posted on Sep 15, 2008
Anonymous
  • 15 Answers
SOURCE: camcorder panasonic displays dew detect in red
Eject the tape. Leave the tape carriage open. Power the unit off and tent it with a light linen cloth for about 20 minutes in a warm but obviously low humidity area. Emergency/ short time approach: Clean hair blow-dryer. Set for warm/low heat. Turn on and "wave" the warm air into the tape mechanism section about 18 to 12 inches away from the camera's open gate/door. Bake for 3-5 minutes..
Posted on Jan 14, 2009
Anonymous
SOURCE: dew detected eject tape
como puedo solucionar el problema (how can I solve the problem)
Posted on Apr 18, 2009
It presents an error called DEW Detected and it shuts down
The unit is wet or it is too humid to work properly. Try to move the unit to a dryer location so the moister can evaporate.
Aug 13, 2010 | Panasonic PV-DV953 Mini DV Digital...
Dew detected for the PL-L750
warm it up put next to heater not to hot.. don`t leave camera in cold
May 15, 2010 | Panasonic PV-L750 Camcorder
Dew detected show on lcd
The camera is telling you that there is moisture inside the unit, place the camera in a warm dry space for 24 - 48 hours to dry out, it should be fine after that.
Regards
Aug 01, 2009 | Panasonic PV-GS300 Mini DV Digital...
Camcorder panasonic displays dew detect in red
Jan 14, 2009 | Panasonic PV-GS39 Mini DV Digital...
Dew detected eject tape
Dec 19, 2008 | Panasonic PV-DV103 Mini DV Digital...
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
Dew Detected
dew detect comes from moist that gets on your dew detect sensor. This prevents any moist from damaging the tape or mech. if moist gets on your tape it will stick inside your mech. if you have not been in a moist area then the sensor could be faulty or your main pcb could be faulty.
Feb 24, 2008 | Panasonic PV-GS39 Mini DV Digital...
Panasonic DV-PV203
Read the solutions here
http://www.fixya.com/support/t196433-dew_detected_dv_203
Jun 12, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Dew detected error signal
Good Luck,
Luwangula
Nov 11, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Video Cameras Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
