We have a range of recipes online at Weber via the link that may work for your oven!
BBQ Recipes Food Ideas Weber New Zealand
Thanks!
SOURCE: I have a Neff Microwave/Oven/Grill
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
SOURCE: Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
SOURCE: my ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
SOURCE: I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
