Ovens Logo
A
Anonymous Posted on Aug 20, 2017
I used the pyrolitic function on my Miele oven yesterday and today the oven won't heat up. Have checked troubleshooting guide but can't seem to find an answer
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 • Ovens
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 • Smeg Ovens
1helpful
Got error "pyrolitic interrupted" any way to clear this swithed of power for 24 hours to no effect
A feature of certain Smeg ovens, Pyrolytic cleaning is an automatic cleaning function which works by heating the inside of the oven to 500°C, at which temperature any grease stuck to the walls is simply burned off.
i think something is wrong with the elements
or a sender / sensor
so as its telling the controller for the oven that its not getting to the right temp perhaps one half of the oven isnt running etc
perhaps some sensor has become worn at these hi temps i cant see a senor lasting more than a few years before it degrades
May 05, 2015 • Ovens
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 • Ovens
I have a new (about 7 months old) SMEG SAP112-8 60cm Linear Pyrolytic Oven. The knob to turn the oven on does not seem to work. You usually push it in (and meet some resistance) to turn the oven on, then...
We have experienced the same problem. We have a service tech coming to fix it. The knob has come off. It seems that the internal spring has dislodged itself. This will be claimed under warranty. Ours is 5 months old. Our other Linear combo oven and coffee machine seem to be more solid/sturdy.
1helpful
Miele Oven H387. Oven does not heat up. Everything else seems to work fine. All troubleshooting ideas in manual are exhausted. Thanks
If the fan is working o/k, then it is more than likely a faulty element, this is located at the rear of the oven compartment behind a removeable cover.
I have a UMP 404 de dietrich oven user manual
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
4helpful
Fault 23 is displayed on the control panel after using teh self clean function on our miele double OVEN H398 BP2. IT IS NOT LISTED ON THE MANUAL WAHT DOES IT MEAN?
F23 means that the required pyrolitic temperature was not reached during the self-clean cycle. If the other half of the oven does not do this, then it could be a problem with a door lock switch or one of the overtemp sensors.
Damage to lining of Pyrolitic oven
I have a hotpoint, am currently on my fifth oven and this too needs replacing. The pyrolitic lining is flaking off and going onto my food. It's coming off the roof as well as the walls so is not just from impact with trays.
10helpful
2answers
Can't use my Meile pyrolitic oven fault 90
I turned it off at the main power source and then turned it on again and it worked just fine ... no further problem. I would have been mad if I had called a serviceman and had him lust throw a switch and charge the earth !
Top Miele Ovens Experts
Paul Bade
vince
Are you a Miele Oven Expert? Answer questions, earn points and help others
