If you wish to get some details; visit the sites linked here. Pull up older posts. http://electronicshelponline.blogspot.com/http://homenol.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view by mobile or a desktop to see the search box. Mobile view has no search box.}/
You should adjust the resolution by the lap top, to adjust the full screen view on TV. Not with TV. Refer the user manual to your system, to know more how to do this. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
Screen shots to defects are given. You can see and compare it to that of your TVs'.
It sounds to be panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD panel are given. Fault to LCD panel for all; irrespective of its brand is the same. You can check it and make confirm.
Back-light inverter board fault. Contact any service technician, or authorized service centre for Panasonic. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Nope. The picture resolution has to be 1080 to fill the screen completely. Using stretch and zoom will distort the low rez pictures. No option to change resolution on the TV itself.
You cannot. The simply answer is the commercials (being fairly new) are actually HD 1080p/i. The TV show you were watching was not and still broadcasting in 480p (not HD). This is common for older programs and networks that have not updated.
You can technically "fix" this by switch the TV view mode to Stretch, Zoom, or even possibly have the TV attempt to upscale the video to HD. All of these will result in distortion and/or picture lose (as some of it would be off screen). While missing an inch or 2 might not be a big deal, the resulting grainy picture can be very annoying.
If it is too much and you have to use the entire screen, I recommend going with the upscale option in the menu. It should be labeled like "Display all in 1080p" or ".... 720p". I would also recommend not using "smooth" as an image option because it makes everything muddy and blurry.
I have an older Mitsibutishi 52" HD 1080. I recently upgraded my cable box to DirecTV HDTV. When I change to format to view in 1080 the TV goes from full screen to what seems to be wide screen with a black bar on the top and bottom. If I change the format to 480p I get a full screen; but the picture has a "redish tint" over it as if looking through sunglasses...I tried everything in my TV manual even call the cable company. Any suggestions?
