Question about Bulova Watches
What size spring pin do I need to fix the the bracelet of my Bulova 96B98? This is a spring pin and not a cotter pin.
The bracelet came apart and I lost the spring pin that keeps it in place. Does anyone know the size of pin I should use to fix it (length and diameter)?
Posted by Iain McCorquodale on
5 Related Answers
Anonymous
SOURCE: want to reduce length of omega watch bracelet take out the pins
how to take out a link in a seamaster profesional
Posted on Nov 18, 2008
Anonymous
SOURCE: geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
Posted on Dec 10, 2008
Anonymous
  • 17 Answers
SOURCE: how do I remove extra
there shoulf be screws on the side of the watch to remove. If not they will queeze together and pop out and you will need a tool to do this with. So basically if that the case you need to take it to a dealer or shop and have them remove it. Thats the case with some high end watches.
Posted on Dec 16, 2008
Anonymous
SOURCE: need instructions for resizing a Link Tag/Heuer Watch bracelet
Hello! I just went through the same thing. If you got the watch new, you can look in the box to find "mini" or "half" links included with the watch. There is no fine adjustment on the Link, but you can replace the larger links with the "mini" links to get the size closer. They are not quite half size, more like 65% of a regular link. So if you add one "mini" link and the watch is too big, you can then replace a regular link with a "mini" link to keep adjusting the size. I went to a dealer (Jared does this, as does Torneau...you talked to the wrong person) and it took about 5 minutes and was $15.
Hope this helps.
Posted on Mar 14, 2010
gemineye61
Janelle Schoonover
  • 842 Answers
SOURCE: How do I adjust the
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Posted on Aug 21, 2010
    Caravelle by bulova 43b17how to adjust Stainless steel bracelet
    To remove some links: If you don't have special tool, at least you have to have something really hard and thin (like the pin you use to post notes on the cork board). Put that pin in to the tiny hole between links where the bracelet pin is and then press/push it forward (follow arrow direction as shown on the inside of the bracelet links.) When the bracelet pin comes out at one end, pull it out of that end totally.
    After removing one links, connect the two links next to each other by placing the bracelet pin back into the hole and push it to the other end.
    To add some links: You have to have spare links and do the same way with the pin to attach more links.
    Feb 17, 2011 | Watches
    How do you adjust the band on the watch?
    For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
    You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
    Aug 05, 2010 | Bulova Watches
    How to take links out of 96D10 bulova watch
    Jul 31, 2010 | Bulova 96D10 Wrist Watch
    Adjust the band on my merona watch
    at the back side of bracelet you can find direction mark, use fine and strong pin with tiny hammer to remove pin out. if there no mark , just look at both side of bracelet, thru narrow hole push your pin, then fastening pin come out thru wider hole
    Feb 23, 2010 | Bulova Watch
    I inherited the watch but not the manual. I don't know how to operate it.
    Here is the Bulova website that has manuals for most of their watches.
    You can print out the manual for free...
    Did this help? Good Luck.
    http://bulova.com/service/servicecenter.aspx
    Jan 08, 2010 | Bulova Marine Star 96B98 Wrist Watch
    How to remove links from band
    This band is put together with cotter pins. To remove the cotter pins look at the edge of the band. The end of the pin that comes out is split and looks like a screw. The end that is solid is the end you want to push from. Use a small punch to push the pin out. The split end is the bigger end of the cotter pin so it needs to come out and go back in the same way it came out. Make sure you remove an even number of links on each side so the watch sits on the wrist the right way. You also have a micro adjustment on the clasp. To adjust the clasp simply use a punch to press the spring bar in the clasp in until it moves. This is a spring bar so be careful it doesnt jump out if the clasp comes apart.
    Sep 22, 2009 | Festina 16177-4 watch Watch for Men
    I need to adjust a Casio AMW320rd-1A9 STAINLESS WATCH BAND. ADVISE PLEASE
    Sep 19, 2009 | Watches
    Trying to shorten stainless steel watch strap
    You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
    First you have to find out what sort of pins or even screws are used to keep links together.
    Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
    NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
    After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
    Job done!
    Don't forget to rate, please.
    Feb 27, 2009 | Bulova Watch
    Need pin for band on Fossil Am 3754
    Measure distance between the lugs of your watch. Find the nearest watchmaker and ask for spring lug of that size (this is if you need to attach band to watch).
    If you need a pin for bracelet links- measure width of bracelet and ask for split pin of that size.
    Dec 18, 2008 | Fossil Watches
    Link removal
    here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at [email protected] 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: [email protected] Copyright © 1999-2006 webjeweller.com. All rights reserved.
    Aug 10, 2007 | Fossil AM3425 Wrist Watch
    Watches Logo
    50 people viewed this question
    Top Bulova Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Anthony Ward
    Anthony Ward
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
