Heating & Cooling Logo
I have a small 5000 btu window unit air conditioner made by arctic king does not have a hole for the excess water to drain.
I have a small 5000 btu window unit air conditioner made by arctic king. It does not have a hole for the excess water to drain from and I'm wondering how it is suppossed to drain. I am concerned about mold growth and build-up. I can hear water gurgling noises at night while it is running in our bedroom.
jack morton
    Master:
  • Heating & Co... Master
  • 523 Answers
I've repaired a lot of window units because someone has drilled a hole in the pan, to drain water, and hit the coil. Please do not drill any holes in anything! These units utilize condensate water to help reject the heat in the outdoor coil. If water is reaching the outdoor fan, it either does not have the proper "lean" or slope, or it's designed to allow water to reach the fan, and not much you can do. If it is designed to allow water to cool the outdoor coil, and you were to drain that water so that no condensate water cools the outdoor coil, this will allow the unit to operate with an excessive outdoor coil temp, and shorten the life of the compressor, or cause the unit to operate poorly/warm supply air temp. Try to give it just a little more "lean". Hope this helps!
Posted on Aug 19, 2017
Thomas Woodburn
  • 2,630 Answers
The coil and pan need a good cleaning.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Aug 18, 2017
1 Related Answer
jack morton
  • 523 Answers
SOURCE: I purchased two Artic King 10,000 BTU Air Conditioners. The base of the units on the exterior of the building build up with water up to about 1 deep when it rains or running. Why is there no drain?
If you look inside the exterior part you should see a copper tube(part of the refrigeration tubing) that rests horizontally under this water. The water cools the freon inside that copper tube. That's why some models don't have a drain there.
Posted on Jul 30, 2015
1helpful
2answers
Arctic king window air conditioner. Purchased a 5000 btu unit. Installed it and been running several days. I see no water dripping from back of unit. Is this ok.
It is perfectly fine if the building is cooling and isn't humid. Once the A/C system saps all the moisture out of the air, it won't drip much if at all until there is more humidity. For more info on why they drip and when ... Why is my central air conditioner dripping water
2helpful
Is there any kinds of problems with this air conditioner
Betty , Media of China makes Artic King A/C, as Andrew stated best to check the reviews from various sellers on line. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Review of my Arctic King 5 000 BTU Air Conditioner
Arctic King 5 000 BTU Window Air Conditioner 115V WWK 05CMN1 BI7
Amazon com Arctic King MWK 05CMN1 BI7 5 000 BTU Window Mounted Air Condit...
2answers
I have a 6000 btu window unit. I was wanting to know how the unit drains the water. where does the water come out of the unit at? I could not find a drain hole.
No drain holes on most units that size
The water gets from the front evaporator thru
a small hole you can not see
Then it finds it's way to the outside or back on the
bottom metal pan
It is evaporated by the condensor fan
It may drain out over the rear pan lip, if
it gets alot, but no drain hole is necessary
You can angle the unit down at the outside or
rear & you can drill a small hole, but it uses the water
to cool the condenser
1helpful
What can you do to stop the 5000 BTU window air conditioner from leaking water into the house, when it should be emptying outside?
Two things can cause ths problem.
1. The back of the unit needs to be tilted down 1/4" to 1/2". This allows the water in the drain pan to flow to the rear of the unit, where the drain hole is.
2. The drain hole or tube in the drain pan, near the rear of the unit is clogged. Looking for it can be a challenge, because sometimes the clog blends in with the hole. Be persistent in looking for it. You can use a pipe cleaner or an appropriately sized Zip Tie to clear the clog.
Hope this helps you solve the problem.
I HAVE A 5000 BTU G E WINDOW UNIT I PURCHASED AT LOWES LAST YEAR, IT DRIPS DOWN OVER MY PATIO IS THERE A WAY TO INSTALL A DRAIN ?
a plastic pan under the unit with some small hose can divert the water elsewhere. use silicone calk to seal the hose in the hole you drilled in the bottom of the pan NEVER DRILL THE PAN OF THE AC UNIT ! use something to catch the water.. if you drill the unit, you take the chance of hitting one if the AC lines !!! there no fix'n that
Open Questions:
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
