Question about Polaroid Office Equipment & Supplies
I have the Polaroid Pogo Printer and I need the power adapter to charge the battery, where do I buy one
Posted by Rose Adamo on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: Use of polaroid PoGo Zink printer with PC
The PoGo can connect to a PC with Bluetooth only. Once you establish a Bluetooth connection with your PC, simply copy any JPEG file to the PoGo using Explorer. No printer driver is needed, just copy the file to the PoGo over the Bluetooth connection.
If your PC doesn't have Bluetooth, you can buy a USB Bluetooth dongle for $5-$20.
Posted on May 20, 2009
A Soveral
  • 566 Answers
SOURCE: polaroid pogo printer
Here is a link for the Polaroid PoGo User's Manual
Posted on Sep 08, 2009
Anonymous
SOURCE: what password code does the polaroid pogo printer
Passward is 6000
Posted on Dec 01, 2009
Anonymous
SOURCE: i lost the ac adapter/charger for the pogo
Same problem
In Indonesia seems not like you can find this adapter with the typical plug. Customer service seems not to exist. Sending a question via www.polaroid.com gives me an automatic reply including contact details:
From Asia/Australia- Customer Support Japan: +81-3-3438-8828
Did you already find a place where they can help you?
Posted on May 10, 2010
Anonymous
SOURCE: wont print from digital camera
Look in your camera settings and change the connection from USB to Pictbridge. If that's possible then you should be able to connect.
Posted on Jan 01, 2011
How can a Polaroid Pogo printer works without battery, directly connected to current?
If you a reasonably handy you could disassemble the battery pack and replace the cells with new NiCad or NiMH units. They are not complicated and you should find lots of sites on the net that will supply the cells. Alternatively if the unit has a DC socket you should find the voltage and current printed beside it. Try fitting a suitable power pack.
5helpful
2answers
1helpful
The batterie wont hold charge bought new one still same problem
Its cheaper to get another one as it sounds to me like there is a component problem on the circuit board which is part of the charging circuitry that charges the battery when power is applied.
4helpful
I have the polaroid pogo. how do i open battery door?
Assuming it is the PoGo instant mobile printer ... (and not a digital camera - category that you posted your question) ... slide the battery door cover downwards to open.
See the illustration in the 5th page of the manual (under installing and charging the battery): http://office.manualsonline.com/manuals/mfg/polaroid/cza10011.html
Need an ac/adapter charger for a polaroid pogo camera
I had trouble finding one for my PoGo printer and finally found these people by calling Polaroid and being re-directed here. They may have adapters for the PoGo Camera also. The number is 1-800-765-2764 and listen for options.
Hope it helps and let us know if it works for you.
1helpful
I lost the ac adapter/charger for the pogo
Same problem
6helpful
How can i use my polaroid pogo with my laptop?
This should work. First check your Notebook to see if it is BlueTooth enabled. If not don't worry you'll need to buy a USB Dongle. (about $8.00 street value Check eBay.)
Go to Control Panel >BlueTooth run the wizard. Enter code 6000 the code to recognize your Pogo. Normally the Pogo will accept a jpeg
from your camera. If you intend to manipulate your jpeg in any way say with Photoshop - I mean crop or enhance - sharpen, hue, saturation changes you might not have any success. There seems to be very little technical info for the Pogo printer. Very poor of Polaroid such a well respected name.
Colin
30helpful
2answers
Battery
Install the battery (see above steps).
Connect the AC adapter to the printer and the power source.
Notes:
Before using the printer on battery power, fully charge the battery for
2.5 hours.
You can print photos while plugged into the power source.
Top Polaroid Office Equipment & Supplies Experts
Steve Nordquist
Steve Nordquist
W.L.
Clive
Clive
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
