H22 means the dishwasher set for a delay start ie it will start after 22 hours. If u keep pressing + button and get that sign to H00 and then start your dishwasher it will start immediately.
EXCEL view the operation as a function fX and you enter it like this: =MINUS(H21,H22) This will show up in the cell and on the function bar above the column letters. The cell number would have a value in it. In this example H21 would have the value 10,and H22 would have the value 5. The formula would reside say in H23 and would show the result of the operation as 5.
10
5
5 (Formula in cell is as shown above)
ok so hear me out, DO NOT! i repeat, NOT buy a h23... honda stopped making this motor completely in 97 these are the worst motors in the world! i know, your rod bearing blew, I KNOW! ive donr 30 of them. Buy an h22 swap for your car... or just the motor.. everything bolts up the same...then if you wan the performance wire up the vtec... 92-96 preludes came with the option of an h22... if you could find one out of your year model and not out of a 97 up, that would be best so all your vaccum lines are the same... youll have to use the h22 harness and ecu.. if its standard, you need to use a standard h22 harness, if its automatic, use an auto harness
hope this helps
replace the motor mounts that are bad
If i were you i would use the wiring harness from the engine that you have transplanted into your car,failling that there could be either a mechanical or electrical problem with the engine that you have transplanted, have come across problems like yourself in the past very frustrating and time consuming but you will get there in the end transplanting two different engines is never easy.
did you change the fuel pump to a higher flow pump, a stock accord pump cannot meet the demand of the h22, also some thing to to look at the main relay, did you upgrade that
That depends on what motor your accord came with, If was the f22 it does work but requires some mods. Providing that the vechile you are installing it in is OBD1 also.
