SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
SOURCE: DVD Player does not work
General
Problems
Player won’t work (locks up)
Try unplugging the AC power cord and plugging it back in.
Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON
button while you press and hold the STOP button—wait at least 3 seconds
before
you release both of the buttons. You’ll need to set up your menu preferences
because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the
contents of the Disc Library.
SOURCE: On Off Code for Sens 22" HDTV/DVD Combo unit
I just purchased the 19' SENS LCD TV + DVD and have DirectTV and was able to get the tv to work with the remote using Samsung as the manufacturer and 10178 for the code.
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
