Question about Champion Garden
Spark plug heat range chart
What a colder plug for a champion RC12ECC by 1 or 2 lower
Posted by koekoehler on
5 Related Answers
emissionwiz
Marvin
  • 85239 Answers
SOURCE: resistor vs non-resistor spark plugs
resistor spark plugs make zero diff in the way the engine runs, they supress radio noise only, this electrical noise can interfere with the cars radio and other electronics.
Posted on Aug 29, 2009
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: where can i find champion A-6G spark plugs for my 1986 Ferrari
Check the "cross reference:
Champion / NGK
A6 / DR8EA
A6G / DR8EIX
Visit here 1986 FERRARI 328 GTS 3.2 V8 F105CB FI
Good luck.
Posted on Sep 04, 2009
joughton
John Oughton
  • 40 Answers
SOURCE: I've got a 1977 dodge sportsman mb 400 with a
The recommended plug for this motovehicle is the Autolite ASP 85. A number of Champion plugs should fit, including: RJ12YC, J12YC, J11Y, UJ12Y.
Posted on Nov 25, 2014
Ted Maxwell
  • 3519 Answers
SOURCE: what plug i need to replace the older L-78 champion spark plug that worked so good for me in my MC91a kart engine
Hi David:
Here's a link that will give you all of the crosses:
http://www.sparkplug-crossreference.com/convert/CHAMP_PN/L78
Cheers
Posted on Mar 21, 2016
sveeden
S Sigs
  • 406 Answers
SOURCE: CHAMPION N5 SPARK PLUG EQUIVALENT IN NGK BRAND
NGK B6ES = Champion N5
Spark plug cross reference
Posted on Jul 29, 2016
What is the correct NGK spark plug for my 1967 Triumph Tiger
I get two numbers...,
L6G or a L82C Champions
the L is the reach (1/2") and the numbers are the heat range.. On a Champion spark plug the lower the number the COLDER the spark plug.. the higher the number the hotter the spark plug,, If you look at the spark plug hole, you should be able to tell if the length of the threads in the head are about 1/2" deep..I would start with the L6 if you can get it.. if it runs without fouling.. keep running it.. if it fouls..looks black and sooty.. go to the L82.
Jun 13, 2017 | Triumph Motorcycles
A champion plug 12jyc what moter will it fit in
plugs for 350 block , 4 barrel carby 1967-19710 is j12yc
all plug descriptions have a series of letters number and letters..you can download the champion chart from the champion plug site
it works like--- this any plug that will screw in the hole will provide a spark
you have to measure the thread length in the head as the plug thread cannot be longer or shorter that that length
next the sealing is by taper or copper gasket so the plug will require the same as is in the head ( flat or taper ) whether the electrode protrudes or not depends on the application ( High speed engine etc)
there are factors that come into it as well like the heat range ---cold plugs for new engines and hot plugs for worn engines to burn the oil
Mar 13, 2017 | Cars & Trucks
NGK y-116v glow plug change over to Champion glow plug what part number???
very difficult to get a cross reference for champion
I did come across a code to explain the part number
it reads like this the Y denotes sheathed type earthed through the plug body
the first 1 is the thread diameter + 10 mm
the next 1 is the battery voltage ---4-12 volts
6 is the serial number
V denotes it is fast heat or rapid glo type
reference -ngktk.co.uk page 114
so if you can get a champion glo plug chart , you are looking for a glo plug that is earthed through the plug body, is 10 mm thread dia is for 12 volts ( serial no is optional , and is a fast or rapid glo type
take the glo plug to a diesel specialist repair shop and see if they can cross reference or have a plug that will do the job
consider it doesn't have to be champion brand
Oct 01, 2016 | Ngk Commercial Series Spark Plug, glow...
Can I replace my Champion CJ2Y spark plug out of my Paulon chainsaw with a Champion EZ start 5861 plug?
Find a spark plug cross reference chart online and lookup your application.
Oct 02, 2014 | Garden
Spark plug gap settings chart
The spark plug gap depends from the engine make/model, not from the spark plug type.
Usually all engines will run with a gap between 0.7 and 1.00mm
Jul 30, 2014 | Champion Spark Plugs Marine Spark Plugs...
gap is defined by motor your putting the plug in
Jul 17, 2014 | Champion Spark Plug / Champion/rl95yc
Ngk spark plug gap chart
usually around .028" - .032"..
n
g
k
r = resistor
b=thread size = 14mm
z
7 = heat range - NGK, the lower the number the hotter the plug. Other mfg. are opposite - higher number=hotter
h = thread length =1/2"
s
-10
These are THE important ones... the rest are mfg. specifics
May 25, 2014 | Mercury Boating
Resistor vs non-resistor spark plugs
Aug 29, 2009 | 2002 Ford Mustang
Garden Logo
102 people viewed this question
Top Champion Garden Experts
Lawrence Oravetz
Vernon Taylor
john h
Are you a Champion Garden Expert? Answer questions, earn points and help others
