Question about IBM E74 17" CRT Monitor
Monitor when i turn on the system.at the boot time when the screen is black some two three lines appear about two to three inches in length.n ya these lines are horizontal.nowadayz those lines hav srarted coming even when the booting process is complete.i mean when working on the system. plzzzzzzzzzzzzz help !!!
Posted by innocent guy on
  • mdhaziq1985 Nov 11, 2008
    this problem is always come to me but this solution not solved my problem if you send me urgently this type of solution i am very thankful to you
    thanks & regards
    Hazique
advanilbnair
    New Friend:
1) when the courser is moved blue colour appear in the path.
2) there are two cursers seen.
Posted on Aug 27, 2011
Anonymous
Capacitor (either ceramic or electrolitic) that connect to vertical ic (TDA8173 or TDA 9302) is short or open. Check all capacitor in vertical range. tq
Posted on Apr 17, 2008
POS X Evo TP1 A1N screen appears to be off, but power is on
first of all check your monitor. it would be the best if you can plug some other monitor just to check... if your monitor is OK then probably you VGA is bad and you`ll have to change it.
Dec 14, 2013 | POS X POS-X EVO TouchPC (PXI-EVO-TP1-A1N)...
One inch white line when booting slowly becomes solid
If you'r not expert fixing laptops send it to repair shop to check screen cable it might be screen data cable problem like it loose or need replacement if this not the problem then Ohhh time to change the screen...Good Luck
Feb 03, 2013 | HP Pavilion zd8000 Notebook
There are 24 black lines (one inch to 3 inches in length). coming up from the bottom of my Dell Inspiron 1545 laptop computer. After awhile the lines start getting squiggly, turn purple and spread out...
Try to connect an external monitor to the laptop if the lines are there then it's the video chip on the motherboard. But if you don't see ant lines on the external then it's the LCD on the laptop and it can be replaced. If you can't perform the work yourself take it to a local repair shop.
Mar 04, 2011 | Dell Computers & Internet
My Dell E2209WC have black horizontal bands/lines all over the screen.
if the lines are like blinking and appearing and vanishing, then try adjusting the cable attached to your monitor or buy a new cable that is attached between monitor and system unit.
Feb 22, 2011 | Dell 2209WA 22 inch Monitor
Today while a user was trying to get online using IE, the machine froze and the monitor went blank. The monitor had red lines appear about 1/2 inch apart and froze. The machien qwould not soft boot. I did...
Your startup got corrupted. If you have an emergency boot floppy, you should be able to get to DOS. This may not work unless Floppy is in your Boot order. If your lucky, you have a cd/dvd in the boot order. Try to put your original XP or Vista disks in and see if you can boot. You can then see files.
Nov 10, 2009 | E-Machines T5048 (7136) PC Desktop
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
Booting problems with my Toshiba Satellite P105
Try to reinstall the video driver from Safe mode.
It appears your hard disk is OK but the operating system and or registry is corrupted.
1. Try installing the video driver first.
2. If it still does not work, back up your data files in Safe Mode then re-install XP again, make sure you delete the partition and create a new partition and do a full NTFS format, not a quick format.
Nov 12, 2008 | Toshiba Satellite A25-S207 Notebook
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
IBM E74 17" CRT Monitor Logo
120 people viewed this question
Top IBM Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
