Question about Ricoh Office Equipment & Supplies
Hello, I am working on a Ricoh copier model number MP2000LN2 and I have this error (sc500)
RAFAEL ESPINOZA GARCIA
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Tienes un bloqueo del motor principal, ya sea porque t? PCU est? ocasionandolo, el motor este da?ado o los engranes que est?n siendo girados por el motor alguno este da?ado
Posted on Aug 28, 2017
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: ricoh aficio mp2000
Turn off the power for at least 5 to 10 minutes and then on. That code means that the main motor is locked.
Posted on Jun 02, 2008
Anonymous
SOURCE: Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Posted on Mar 12, 2009
mazeman
  • 7 Answers
SOURCE: error code sc500
Your main motor is hard to turn.. Check your Drum unit. Pull it out then on the back side you'll find a small agitator gear then tried to turn it. If it doesn't rotate then you might have to change its paddle gears, idle gear or that development sleeve is stuck. Hope it helps.
Posted on Apr 20, 2009
quennie732
  • 422 Answers
SOURCE: Ricoh Aficio 2018D
This could be a very bad code its "main motor lock", either you have too much load on the drive unit ( paper stuck, locked up pcu or fuser ) and maybe bad BICU board.
-Carl, please let me know if this helps.
Posted on Jun 27, 2009
Anonymous
  • 114 Answers
SOURCE: I have tried resetting ricoh aficio 161 showing
Main motor error SC 500 The main motor does not reach its operation speed within 0.7 second, or the main motor remains out of its operation speed for 0.7 second after reaching the operation speed. ?? Overload ?? Defective main motor
Posted on May 01, 2010
Testimonial: "Thank you very much! Really appreciate your response :)"
What is error sc500 of mp161
could be the right side door is not latched properly
2answers
What is SC500 error on Ricoh Aficio 2020D?
gear assy not turning can be many things. Main motor/devlp unit /fuser/ transfer roller
Error sc500
SC 500 Abnormal manual feed drive motor speed.
Sc500
"Main motor lock" Check the drum/dev unit that can cause this error code.
SC 500 error code on a Ricoh MP161
main motor can turn that is why getting code. can be from photo conductor, to fuser or gear broke in back of copier. Will need tech for this one.
6helpful
I have tried resetting ricoh aficio 161 showing error sc500, no luck , any offer of help appreciated
2helpful
2answers
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
3helpful
2answers
Error code sc500
Ricoh aficio mp2000
Open Questions:
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
