I am going to check power coming out of LED power supply to see if that is the problem. If it is the back lights how many LED strips are in my TV?
SOURCE: gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
SOURCE: difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
SOURCE: BLACK SCREEN NO AUDIO POWER LIGHT IS ON
Since the screen is coming on I do not think it is a problem with the power supply. It sounds more like a problem with the audio/video main board of the set. Is the set under warranty?
SOURCE: I have a Samsung 56"
Actually the Samsung model you have was the first model to come out in 2006 that did not have a color wheel. The LED blinking is actually a self diagnostic program of sorts. Depending on which lights are blinking, and how often, the service manual will tell you where you should start checking or replacing parts and assemblies. I do have most of the codes, so can you tell me if the if the LED light is the only one flashing, how long it flashes, and do any other lights flash at all? Thank you.
SOURCE: i have a samsung ue46d6750
hi iv just bought a samsung ue46d6750 every thing is ok but i cannot switch the
smart tv logo off its in the left hand top cornor help
