Question about HTC Computers & Internet
Have replace HTC One Max battery will not show indication of charging will not turn on no response whatever need help
Posted by Felix Brown on
5 Related Answers
Anonymous
SOURCE: s-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Posted on Dec 02, 2007
Anonymous
SOURCE: Pentax K10D Both LCD screens are blank
Did you put a memory card in the camera?
My camera did this today, and I resolved it by putting a memory card in, but even when one has been out before it still turned on, so I'm not sure that is the resolution. Did you ever find out what was causing it?
Posted on Mar 28, 2008
Anonymous
SOURCE: battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Posted on Aug 17, 2008
Anonymous
SOURCE: Replacing battery questions
I have almost the same problem. I need another battery exactly like the one that came with camera, but I can't seem to locate a store that carries the battery. Can I substitute another type of battery in it's place?
Posted on Oct 10, 2008
Anonymous
  • 4 Answers
SOURCE: Sony Cyber-Shot DSC-W7 Digital Camera--battery problem
To solve this open the camera and remove the battery chamber (be careful with the cable that joins the chamber with the main board because it is very fragile). Once you have the battery chamber clean all the contacts with a contact cleaner. By all the contacts I mean, the 4 contacts for the batteries and the two contacts (male and female) that join the main board and de chamber. Be careful when you apply the contact cleaner to the main board contact bacause it is a liquid and might harm your lens if it reaches it. I have made this with my camera and worked awesome.
Posted on Jan 01, 2009
My HTC evo Design 4g wont charge with new batteries and new HTC chargers. The devices indicators say its charging both the orange LED and the green battery icon on the screen show it charging but it dont...
You're battery and phone may be HTC but your battery may only be 3.2 V while your phone is 5v try looking at the battery output and the phone output they are both in the battery compartment. I had the same problem with my HTC EVO V
Oct 20, 2014 | Cell Phones
Any solutions to dewalt 20v lithium battery charger got wet shows blinking light as if its charging normal but not charging
High Performance Current Mode Controller doesn't work for you in the charger. According to the link, scheme.http://kazus.ru/forums/attachment.php?attachmentid=51161&d=1377505983
Sep 18, 2014 | Dewalt 12v Max - 20v Max Li-ion Battery...
Htc amaze battery life
Oops, it does not have to be, at times, I meant, supposed battery failure
If the battery contacts/pins for your phone/tab are not making contact well with the battery terminals/heads...you will experience such, constantly.
If the battery does not sit/fit well in its compartment, you will still experience same as you do at present. This is because, the battery is making partial contact with the terminals/pins.
Check these; whether your battery sits well and fits perfectly in its compartment inside your phone/tab.
Check whether the terminals are contacting well
Aside of these, you may need to either replace your cellphone/tablet's battery and watch what happens.
Feb 05, 2018 | HTC Amaze 4G Android Smartphone
My htc inspire won't turn on what do i do ?
Make Sure if Your Baterai if Fully Charge.
Because if the baterai Over Low,when you charging it will need 5 to 15 minute to show Charging indicator Progess Bar.
And if the baterai over low,Cellphone will only Show Black or White screen in a couple second when turn On and then off automaticly.
Jan 06, 2012 | HTC Inspire 4G Smartphone
Hitachi DMP850N When Connected to PC charging battery shows progresive charging When I use USB charger (Output 5v 400mV Max) the battery charge indicator doesn't change
the usb chargers 's transformoer might be having fault ...u have to replace the usb charger as a whole bcoz only transformer is not available ...
Oct 17, 2009 | Audio Players & Recorders
((G1 Will Not Turn On)) When The Fone Is Off The Charge Light Shows But Will Not Come On
your phone's charger may be broken. the red light also indicates a dead battery or needs charge immediately. try using another usb charger to see if it works.
Aug 12, 2009 | HTC G1
Please help, I can't turn on my HTC. What happened?
If you have a charged battery insert it and power the phone. If it hangs or whatever then (with the phone powered on, regardless of what's been displayed) keep on the keypad the two dashes ( - ) pressed and do a reset with the stylus. Do not leave the two buttons untill a black screen appears and ask you to press send (the green call button). Press it and you are done. If your phone doesn't have a hardware damage it should start. It will start from scratch again so you might be a bit patience.
Oct 08, 2007 | HTC P3300 Smartphone
Computers & Internet Logo
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
