Https://www.sony.jp/cyber-shot/emdown/data/T200_T70_im_GB.pdf
dont forget to donload and keep it safe on your pc ...
happy to help
Testimonial: "thank you very much for your advice and help,very much appreciated, regards andy"
SOURCE: How long time I churge "SONY NP-BG1 Battery
The first charge you should let it go overnight, so it has a good solid charge. After that it depends on the mAH of the battery, the higher the number, like 1400, it should take about 3 hours. There should be a led light on the charger, its red when charging and turns green when completed. The chargers have a voltage regulator on them, so that you can't over charge a battery.
SOURCE: Sony Cyber-shot DSC-W30 Digital Camera
If you want to reset DSC-W30, press Menu and go to Initialize, select it and press OK
Camera will be RESET and go to factory default settings.
SOURCE: Sony Cyber-Shot DSC-P32 won't connect to computer
I think you have a wrong setting, go into the menu and go through it and it says USB connect or something to do with PAL/NTSB i don't have one in my hand.
SOURCE: Sony Cyber-Shot DSC-H1 Digital camera that will not hold a battery charge
Aparently you have to use sony batteries with a sony charger. I have the same problem and have been trying different batteries because I thought what's the difference with batteries as long as they are rechargeable? I spoke with a guy at the sony store and he told me to use sony batteries with the sony charger I have. Don't know if he's talking BS or not but I'll give it a shot and see if it will hold a longer battery life. When I bought the camera it was great but now it dies really fast! I'll let you know how things turn out! Until then, if anybody else has a suggestion let us know so we can enjoy our H1's!
