Hi, I had the same problem with my Siemens EQ.300. The problem was residues that are sticked to brewing unit. Here is the solution for my Siemens EQ.300
Take a plastic brush and clean all part of the brewing unit, deeply, under tap water for 5 minutes. Dry gently, and re-inserted to the Siemens EQ.300 machine.
Update: After a while, same problem happened again. This time, I have washed my coffee machine's brewing unit in the dishwasher. Result is perfect!
If battery power was lost for some time, the radio theft control might have activated. Look inside your glove box wall for the radio reset code. Owners manual usually contains detailed steps to reset.
talk with your local office suppliers or good hard ware shop for longer staples for the machine
the problem you will have to consider is the length behind the staples that will restrict how far down the sides of the container you can staple
box and carton staplers are available on line , are foot operated and have considerable depth for the purpose of containers and boxes or there may be a local supplier that will have a machine better suited for what you want to do.
Unplug it from wall wait a minute then plug it back in. If that doesn't work call the manufactures help line located somewhere on the machine by a sticker or tag
Normally there is a box in the wall with the wires contained therein. I would then connect the wires to the appropriate screws and then align the screws on the socket to the box that is in the wall and tighten them. Then I would put on a cover plate and call it finished.
If the box is not in the wall then go to a big box store and get a rework box, the sales people will be glad to help you.
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
