It seems that I've forgotten my admin password seems to have. I use it to logon to my pc for everything ,I know I should have two accounts, one user and one administrator, so, now i need to reset the administrator account, but how? i don't want to lost my data.
Rescued the neighbor's daughter's laptop recently with TunesBro. Took less than 5 minutes to recover the password. Was an Windows 7 machine though... Forgot Windows 7 Password Can Reset Windows 7 Login Password
SOURCE: forgot the username and password for my windows xp admin account
try to boot in safe mode and remove the password
SOURCE: i forgot admin.password...plz help "windows XP version 5.1"E-machine
YOU CAN CREATE ANOTHER ADMIN ACCOUNT USING DOS MODE....
SOURCE: Forgot username for admin acc in windows xp
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
SOURCE: Admin account on Vista pc locked out, forgot admin password
Step 1
START THE COMPUTER. DO THIS BY PRESSING THE POWER BUTTON. DO NOT WAIT UNTIL WINDOW LOADS TO PERFORM STEP 2.
Step 2
PRESS F8 KEY ***BEFORE*** WINDOWS VISTA BEGINS START UP. THIS WILL PROVIDE A LIST OF OPTIONS FOR HOW TO PROCEED.
Step 3
CHOOSE TO START YOUR COMPUTER IN "SAFE MODE".
Step 4
OPEN THE START MENU.
Step 5
OPEN THE CONTROL PANEL (from within the Start Menu).
Step 6
SELECT "USER ACCOUNTS AND FAMILY SAFETY" IN THE CONTROL PANEL POP-UP WINDOW.
Step 7
CLICK THE "CHANGE YOUR WINDOWS PASSWORD" LINK BENEATH THE "USER ACCOUNTS" SECTION.
Step 8
CLICK "REMOVE PASSWORD". VERIFY AND SUBMIT.
Step 9
RESTART YOUR COMPUTER NORMALLY. DO NOT PRESS F8.
Step 10
TO RESET A PASSWORD, ACCESS THE "USER ACCOUNTS AND FAMILY SAFETY" MENU AGAIN. THIS TIME CLICK "CHANGE YOUR WINDOWS PASSWORD", PROVIDE THE DESIRED PASSWORD, VERIFY AND SUBMIT. THIS TIME, WRITE YOUR PASSWORD DOWN.
If this helps please rate me. thanks
SOURCE: How to Unlock Windows Vista Password?
I would like to introduce "Windows Login Recovery". It not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive to recover windows password. Booting up and clearing a password takes a minute or two works like a charm. You can download it from http://www.windowsloginrecovery.com
