SOURCE: GE dishwasher GSD2230 won't drain
Hi Dishwasher not
draining issue usually occurs due to kinked drain pipe, clogged drain filter or
drain pump. Check the drain hose for any visible clogging, remove if present.
If no visible lint is present then remove then turn off the dishwasher and remove
the drain hose and check for any visible clogging. If still not visible then
the drain filter or drain pump is clogged and you'll need to clean the drain
filter and drain pump. Also, check for any food pieces stuck near the pump
impeller. Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat. Hope this helps...
Please post back for any further assistance. Daniel
Hi
Dishwasher not
impeller.
Please note that
doesn't overheat.
Hope this helps...
Daniel
