Question about Bose Audio Players & Recorders
Codes for bose to cox
Iwant to connect my bose surround sound to cox cable
Posted by Jean Spink on
5 Related Answers
Anonymous
SOURCE: Remote Code
codes for bose123
Posted on Feb 03, 2008
les236
SOURCE: code for Vizio HDTV to Bose System
try 0030 or 0178
Posted on Apr 06, 2008
Anonymous
SOURCE: bose lifestyle v20 sound but no video
The problem turned out to be the TV itself. Somehow all the a/v and component cable inputs on the back of the TV got disabled. After finding then consulting the TV manual online (the TV is about 8 years old), we found there was a way to reset the TV to its original factory settings. Voila, the a/v and component cable inputs were enabled again, and everything worked correctly afterwards.
Posted on Oct 01, 2008
Anonymous
  • 8 Answers
SOURCE: connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Posted on Sep 12, 2009
Anonymous
SOURCE: code for Bose cinemate surround system
We just got a Bose Cinemate system and have the same issue - none of the listed codes for the Synergy V work.
Has anybody got this to work yet?
Posted on May 23, 2010
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
I have an older kenwood reciever, and i connected it to the bose 10 3series surround system and it works great! im trying to get surround for my bluray player and tried hooking the audio out of bluray to...
Surround is not carried on analog audio cables. Have you looked at the unidentified BluRay manual? What's a bose 10 3series? Have you looked at ITS manual - try Bose.com to find it.
Sep 13, 2011 | Kenwood Audio Players & Recorders
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
BOSE 38-WHITE BACK:ERROR 801-LOUD SCRITCHING NOISE AFTER SHUT OFF
Hello any cable or satelite tv show is now more comonly in high definition sound and video! and the techs are wrong because their are plenty of movies on tv including news channels that broadcast in surround sound ,but in order to get that surround sound you must either have a connection from the tv,s audio out or you can also out put the sound from the cable or satelite box out to your bose system as as the scritching sound where does it only happen when in surround mode or stereo mode ? if you play a dvd or cd does it still make noise? and can you be more specific on your terminology SCRITCHING not really shure what you mean by that word! thank you glenn mayer
Mar 06, 2009 | Bose Lifestyle 38 System - white Theater...
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Plasma Television Connection
hmm a bit...complicated but if they all use HDMI then one cord is all you need going to the tv from the bose sound system while any other HDMI connection should directly go into the bose sound system or if the dvd player uses RCA then RCA sound should go to the sound system and video directly to the tv
Apr 22, 2017 | DFI LANParty UT RDX200 CF-DR Motherboard
Remote Code
codes for bose123
Feb 01, 2008 | Bose Lifestyle 18 System
56 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
