Question about Braun Health & Beauty
Looking for a model 3756 Braun Charger - Braun Health & Beauty
Posted by Rosina Orozco on
1helpful
I have bought a Braun epilator 7 , Braun type:5377 , in USA and have purchased the charger in the UK which is 100-240 v , do I still need to get a voltage converter to be able to use it in the UK ?
If the charger is 100 to 240VAC, it should work. USA use 110 volt so the charger should be OK with 240. The UK charger will probably have a UK 3 pin plug on it. If you use it in the US, you will have to change the plug again or buy an international adaptor which can be adapted to fit most outlets anywhere in the World.
1helpful
2answers
How to fix a Braun series 7 razor that will not charge in cleaning stand
I have a Braun 7 series that I use occasionally. The last time I tried to charge was unsuccessful. After several days on the charger still would not charge, I discovered the RESET button right under the Braun name. The charger cable has to be unplugged, then press reset with a paper clip and now works like a charm. Note: reset will not work if charger cable is plugged in.
2helpful
2answers
3756 f 136 manual
The User Manual for the Braun Professional Care 500 Electric Recharegable Toothbrush can be found line here:
http://www.service.braun.com/line/OC/O3756/O3756_14_MN.pdf
Should this be helpful, please rate my assistance.
Thank you!
1helpful
2answers
My power cord is lost, what is the alternative
Braun Syncro 7526 power cord is Braun 7030458 charger cord replacement.
2helpful
Shaver Stopped. May need power unit series 569 class 2 for series 1 150
By 'power unit', it appears that you are referring to the power/charging cord. If this is the item you require, you will find this item for model 150 (series 1) at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/braun-charger-cord-for-select-models.html
2answers
My power cord has broken at the tip. Can I
Braun Syncro 7570 power cord is Braun 7030458 adapter charger cord.
2answers
Braun Syncro 7505 Shaver, Need Power Cord.
If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
