Question about The Office Equipment & Supplies
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
Posted by Janet D Powell on
Andrew Taylor
    Top Expert:
  • The Master
  • 33,457 Answers
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Posted on Aug 14, 2017
5 Related Answers
Mix-it-up
Mix-it-up
  • 832 Answers
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Posted on Mar 29, 2008
Anonymous
  • 7 Answers
SOURCE: Brother MFC-210C keeps displaying unable to clean messasge
Hi I found this on your website for this problem, from Poster "Trickydicky": Rank: Apprentice
Rating: 96%, 81 votes
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C): I havent tried it yet but there were many recommendations from users who did and they recommend this solution- Good Luck the service centers said it would be $70.00 just to check it before any work is done. But if it's just a matter of pressing series of buttons to reset the cleaning counter, it's worth trying. REE
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Was this solution helpful? Show your Appreciation by rating it:
Posted on Dec 02, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: printer has unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
Then with the power on, pull the plug from the wall for several minutes. The plug it in and power the unit up.
Here is the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 20, 2008
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: My brother MFC-410CN has an error message "Unable to Clean"
Suggestion.
MFC-410CN unplugged from the surge protector. Open the printer case. It opens in the middle. This is how you get to the ink cartridges.
I suggest at this point, to don a pair of dishwashing rubber gloves.
Remove the ink cartridges. Take a clean, lint free cloth, and soak one end in real warm water. Almost where you can't touch it. Wring the cloth out until it's just damp. No drips will form. Take the damp portion of the cloth, and wipe the area of the cartridges that ink comes from.
This should be where you see a thin copper strip.
After you wipe across once, use a different area of the damp cloth that is clean, and wipe again.
What you are trying to do, is to clean the tiny, tiny, little holes of this ink cartridge, where the ink comes out. What has transpired, is that ink has dried in these tiny holes, and ink cannot come out now.
I also advise doing the same to the area where these holes line up in the printer 'body'. Ink may have dried there also, and cannot pass through.
Once you are finished wiping with damp cloth, and no more dried ink is present, and you are satisfied that it isn't, then use a dry, lint free cloth, and wipe these areas.
Let the ink cartridges set out, until you are satisfied that they are dry. Those copper strips of metal must not contain any moisture.
Same thing for the printer itself. Leave it open to dry out. Probably about an hour. Using a hairdryer set on low heat, and constantly moving it back and forth, while keeping it at a distance of about a finger length, will speed up the process. (For the printer. This is not advised for the ink cartridges)
When you are satisfied that all is dry, reinsert the ink cartridges. Make sure they are properly seated. Close the printer case. Plug the printer back into power. Wait one minute, or until the printer goes through it's setup. (If it does one. Some printers do, some printers don't)
Now press the Power On button for the printer. Let it align itself.
Go to the Brother self diagnostic program for the printer, and use it.
Let it print out a test piece of paper after aligning.
Posted on Apr 15, 2009
Anonymous
  • 787 Answers
SOURCE: my printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Posted on Nov 03, 2009
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
Cannot print 50
please follow ALL the steps on link below: How do clear the message Unable to Unable to Chang Brother Please let me know if the issue is solved or not, so we can continue troubleshooting. Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC J220 Multifunction Printer
Unable cleane 50
Hi Nikki,
Go To Below official Brother Printer Page For Your problem,
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Feb 05, 2014 | Brother MFC 6490CW InkJet Printer
Message says "unable to clean" routine maintenance see troubleshooting guide brother MCF 210C
verify all inks yet maybe one or more is empty and run with new inks and original, clean inks yet in you control panel bottom
Sep 28, 2009 | Brother MFC 210C All-In-One InkJet Printer
Machine Error 51
More than likely you have a bad printhead, if its under warranty brother will pay to have it fixed, otherwise just play baseball with it and buy another one
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
My unit has a unable to clean message on the screen and I do not know where my manual is (just moved) How do I fix this
The ink absorber box and the flushing case will need to be replaced. Then the purge counter and the flushing counter will need to be reset to 0.
Aug 03, 2009 | Brother MFC-5840CN All-In-One InkJet...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
272 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
