SOURCE: how do i unlock an ipod with " ipod disabled".
If you are the original owner of the iPod just connect it to the computer that you first synced the device with.
If you have found an iPod that had a lock code on it and have attempted to guess the passwords incorrectly too many times, I recommend you do the right thing and give it back to the original owner if you can.
If you cannot find the original owner I see no point in letting a good piece of technology go to waste so follow these instructions.
1) Turn off the iPod by holding down the power button (button on the top) and sliding the slider across to shut it off.
2) Find your Sync Cable and Plug it into the computer (just the computer, not the iPod yet)
3) Open iTunes
4) Hold down the home button. (Button at the bottom) While still holding down the button connect the sync cable to the iPod.
This should put the iPod into recovery mode. Once in recovery mode iTunes should pop up a message stating that it has detected an iPod in recovery mode and should allow you to restore it. This will delete all of the data/music on the iPod but will allow you to use it as if it were new.
SOURCE: password solution for apple ipod
Connect the iPod to your computer and go to itunes. Then turn off the ipod. Hold the Home button and then press on the lock button until the apple logo appears. Keep holding the home button until a usb cable and a itunes icon show up. Then itunes will tell you to restore
SOURCE: ipod touch disabled
If you repeatedly enter the wrong passcode, iPhone or iPod touch
will be disabled for longer intervals, before you can try again. After
too many unsuccessful attempts, you won't be able to try again until
you connect to the computer you normally sync with. Note that starting
with iPhone 2.1 software, there is a setting to cause the device to
erase itself after 10 consecutive incorrect password attempts. This
setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your
device on the computer that was used to originally sync the iPhone or
iPod touch so that you can reset your passcode and resync the data from
the device (or restore from a backup). If you restore on a different
computer that was never synced to the iPhone or iPod touch, you will be
able to unlock the device for use and remove the passcode but your data
will not be present.
SOURCE: Apple Ipod Is disabled
Warning: you will lose all your data
Testimonial: " bUT I WANT IT WID OUT LOSING MY DATA "
SOURCE: HELP i forgot my apple ipod toches password and it
You will need to do a 'Hard reset' !
This is how the the procedure goes for the ipod touch:
- While plugged into ITunes, Hold down the power and home keys down for 10+ seconds. - - Screen will go black
- Release the power
button but keep holding the home key until itunes says 'We have
detected an itouch in recovery mode'
- Restore as normal via iTunes
Hope it helps!
