Question about Smeg Kitchen Ranges
I have only had my smeg stove for a month and the flame spreader crowns have stained considerably and I can't get them clean with the recommended cleaning instructions.
Posted by Judith Barry on
Bill Boyd
    Top Expert:
  • Smeg Master
  • 53,816 Answers
Even stainless steel will tarnish with the heat from the flame
all metal discolours with heat so the cleaning products will only be to remove spilt food etc from the hob
Posted on Aug 14, 2017
5 Related Answers
Anonymous
  • 57 Answers
SOURCE: Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
Posted on Mar 02, 2008
Anonymous
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
onthejob5130
onthethejob1
  • 640 Answers
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Posted on Dec 27, 2008
DeBruce
Bruce
  • 145 Answers
SOURCE: black enamel stove top,frigidaire
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
Anonymous
SOURCE: How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
Posted on Sep 17, 2009
I have a new Smeg stove and can't get the gas oven going.
The stove should have a safety valve that needs to be removed upon first use , remove that then open the gas and then iginite pilot flame.
Jun 08, 2018 | Smeg Ovens
Dont know how to get to the ignitor to remove it . its a kenmore gas stove the broiler works but the the oven dose not get hot on bake..
the bottom of oven has a removable cover . two screws in the back l & R then lift out the cover from the back side and the burner flame spreader in under that cover . Remove one sometimes two nuts form the flame spreader and in the center on the back of the burner is the ignitor . remove the two phillips screws and lift out the ignitor. make sure the wire's are disconected in back . reverse this prorcess and you have completed the instalation .. mm
Jul 11, 2010 | Kenmore Ovens
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
Cant get food stains removed from top of stove i use a special cleaner and a special scrub and it still doesnt come off. it can be any kind of stain. the new stove tops are very hard to clean. any help...
I recommend a product called of all things "barkeepers friend". It comes in a can with holes in the top to sprinkle the powder out of.
Moisten the stubborn area and sprinkle this product on the stain then add enough water to make a paste. Make sure the paste covers the entire stain. LET IT SIT FOR AT LEAST TEN MINUTES. Then rub with a wet cloth. It always works for me and I have a black stove.
Jul 27, 2009 | Stoves 12 in. (1248-1100) Electric Cooktop
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Ovens
I have a Goodman GUPI100-5 pilot comes on but wont fire up.
Your flame sensor is measured in Millivolts not voltage. Is the flame spreading accross the burners at all? If it only ignites on one of the burners, you have debris blocking the flame spreader. Clean the burners and flame spreader bar. If you just as you say get a pilot, clean the flame rod.
Nov 24, 2008 | Goodman GMS90703BXA Heater
Toyostove Laser 73 EE2
Not having a cleaning in the last couple years may be the problem. Carbon build up in the burner pot and on the flame rod (a chain of carbon) will cause the flame to not be sensed. Then the flame will burn out. A temp solution would be to unplug the stove, then unscrew and jiggle the flame rod to break the chain. When tightening the screws do not over tighten. You could also try hitting the edge of the pot to see if you can knock the carbon loose. You could also have a warped burner ring which would cause problems keeping the stove running.
Nov 03, 2008 | Rinnai Toyostove Direct Vent Heater:...
Kitchen Ranges Logo
60 people viewed this question
Top Smeg Kitchen Ranges Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
