Question about Electrolux Washing Machines
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
SOURCE: I want to know what
error code e 70 the control board is not seeing the proper water supply amount in this case check the pressure switch as well as the water valve assure that you are getting hot and cold out f the water valve one from each side if the valve is ok then you would move on to checking the pressure switch how much water is fillinig on the inside of the machine when this error happens? if you have any further questions message me back Thanks again Rick
Posted on Jan 23, 2011
This is a siphoning problem. Please clean out the dispenser cup(s) as much as you can and try again. You may need to clean the unit and run vinegar through instead of bleach to unclog any small components.
Posted on Jul 25, 2012
SOURCE: E26 code on Electrolux front load ewfls70jss
Hello ajwalz - Typically E26 indicates that there is a recirculation pump relay. You will need a certified professional to check the wiring between the main control board and pump/recirculation board to determine which part has to be replaced.
Posted on Sep 25, 2012
