SOURCE: broiler element not working
It's either the switch that supplys power to the broiler element or it's the element itself (probably the element itself). I'd go after that first as it's not that expensive.
It's not a thermostat because if it was, the bake element wouldn't work either. The broiler element is not supposed to come on except when in the broil mode or cleaning mode.
SOURCE: the oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
SOURCE: Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
SOURCE: Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
The oven is electric and I am just wondering what the issue might be?
