Toshiba 1560 wrench light flashes
SOURCE: Red "wrench" indicator always on
Press the clear and the 8 button at the same time . This will give you a error code. I will guess that you have a "C7". If you still want to fix let me know error code.
SOURCE: toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV
would not turn On, Red light solid green light blinked 9 times then TV
would try to restart. At first I thought it might of been the bulb, so
I replaced it, same results. Next I replaced the ballast which is
pretty easy, just take pictures before you remove the light engine so
you can go back to the picture to verify the connections when
reinstalling.
SOURCE: toshiba 1360 copier
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
SOURCE: i have a toshiba 1370 copier....the repair wrench
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
