SOURCE: Oven won't work after power cut.
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
SOURCE: Cannot turn on Oven
your oven needs a new ignitor it has to draw 3 amps or more to open the gas valve (just because it glows doesnt mean its good) let me know how you make out
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
SOURCE: Bosch oven HBT346 - how do I reset the clock?
Hi after a power cut my Bosch cooker clock is flashing but I cannot reset it as have no instructions - any ideas? Thx
SOURCE: my bosch oven isnt heating and someone said
Hello, welcome to FixYa.
Yes the Bosch wall oven have a hi-limit resetable cut-out. You will first need to slide the oven out far enough to remove the top panel of the cabinet...it may require two people.
**first though, shut off the breaker at your home service panel...safety first of course**
The reset then should visible once the top is removed and will look like this...
If you locate this and push the red button in the middle it should "click" if indeed it was tripped.
Once you do that you should be good to go...if that`s the problem.
Let me know how it goes or if you require further assistance.
Thank`s for choosing FixYa. Please take a moment to rate the solution provided for you here or testimony if you feel warranted.
Good luck,
macmarkus :)
Testimonial: "thanks for your help I think it is a bigger problem than that unfortunately but I apprecaite the chance to check it out!"
