Question about Epson Stylus Photo R300 InkJet Printer
Epson r300 photos print very dark
When we print photos they r very dark
Posted by sculley on
  • 3 more comments
  • Anonymous Nov 25, 2007
    I have the same problem. photos look great on preview then when printed are very dark.
  • mgcat23 Nov 28, 2007
    picture comes out very dark:(
  • Deiricoduill Feb 10, 2008
    I have the same problem and even though I have edited the photos in Photoshop to make them artificially bright they still look awful when printed.
  • nickbrand Jan 01, 2009
    Same problem. My photo's are far too dark when printed, even after adjusting all the settings in the printer to the brightest.
  • Anonymous Jan 01, 2009
    pictures are far to dark
Anonymous
I had a problem with my colour. I discovered that I had left the tab covering one of the holes on at the top of the of one of the cartridges. Suggest that you check all the cartridges again. Hope that this helps
Posted on Dec 28, 2007
Anonymous
Pictures to dark
Posted on Jan 01, 2009
4 Related Answers
jacklee366
Lee Reynolds
  • 541 Answers
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
you can try and reset the printer with software let me no if you dont haver it
Posted on Nov 18, 2008
Thomas F. Schneider
  • 2715 Answers
SOURCE: Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
Posted on Dec 23, 2008
Anonymous
  • 381 Answers
SOURCE: Epson Stylus Photo R300 is broken
remove the colored not detected then clean the chips then take it back again and turn of the power of printer then on again then see again...thanks...
Posted on May 09, 2009
Anonymous
SOURCE: Epson Stylus Photo R300 sounds like it's printing
I know there are some cleaning cartridges with a chemical thinner that could clean any ink residual that could interfere with proper function of the printing head.
If this doesn't work you probably have to replace the head.
Check also the flat cable that follows the printing head during movement.
Fabio
Posted on Jun 16, 2009
Linked r300 to pc running windows7.can print photos but not cd's.
Download and install the latest print cd software from here.
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R300/Drivers-Support?target=driver&languageId=1&driverId=324514&defaultOSId=3&DRV_CATEGORY_CODE=CREATIVITYSOFT
Dec 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Printing black
i would suggest cleaning the heads.
Apr 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Dec 23, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 Printer
I have seen this issue, which usually happens on Windows XP and Windows picture and fax viewer. The easiest fix is to print from another program on your computer. If this is not the case, you need to provide more information on your issue.
What OS are u using?
What program are you using?
What is the exact paper you are using?
Has it ever worked before?
Is this happening on all pictures?
Sep 08, 2008 | Epson Stylus Photo R300 InkJet Printer
Very dark photos
I have same problem, but it wasnt always like this. The first year I had the printer it was fine. We didnt use it for a while and now all images are very dark. The only thing that has changed is all the other photo management software that was installed with new cameras and accessories. I removed all the "Film Factory" , "Corel Photo Manager 6", and ancillary software, reinstalled the R300 drivers, and still getting dark images. I also played around with the printer settings regarding paper type, color management, and gamma with little to no effect.
Apr 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Help work
try epson.com they have most of their booklets online
steve
Jan 18, 2008 | Epson Stylus Photo R300 InkJet Printer
Photo printing is too dark. I have replaced all print cartridges and it still prints too dark. Thanks for your help.
did you choose the right profile for your printing profile also means the type of media or paper you are using for example is it a photo paper or is it just a plain paper, you have to choose, or else this type of problem will occur.
Sep 12, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
310 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
