Question about Dell Dimension 3100 PC Desktop
Which RAM to use for Soltek SL-75DRV/-v
Currently I have 256 mb PC2700 DDR SDRAM 133mhz on my PC.
What can I use for opgrade RAM on this MB. Can only find PC3200 RAM 3-400 mhz. I whant to add more RAM or by new RAM.
Best regards
Leif Salomon
[email protected]
Posted by Leifs1 on
Anonymous
  • 95 Answers
I HAVE DELL DIMENSION 3100 HAVE RECENTLY UPGRADE MY RAM.
THERE IS ONLY 2 SLOTS FOR RAM.
I UPGRADED MINE TO 2GB AND RUNS AT 667HHZ.
WHICH COST AROUND £45 FROM "MICRODIRECT"
RUNS REALLY QUICK
Posted on Mar 10, 2008
Anonymous
    Scholar:
  • 38 Answers
Leif: The difference in the numbers (2700 versus 3200) is speed rating-- basically, the higher the number the faster the RAM. Your computer is currently using 2700, so it's safe to use 3200, it's just faster than is currently used/specified.
Your computer is a Socket A - AMD Via-based board, so it is likely the motherboard will accept 1 GB memory modules. With three slots open, you would want to buy 2, 1-GB modules for best results. At current pricing, that would cost about $100. 2- 512MB modules would be next-best and around $55. Be sure to place the two modules in the slots next to each other, and closest to the processor for best results.
Posted on Nov 22, 2007
How many pins in the hyundai ddr 512mb?
SO- DIMM 512 MB 333 Mhz / 200 PIN PC2700 64Mx8
DDR SDRAM memory has 184 pins, where as SDRAM has 168 pins. DDR SDRAM Memory is a new type of SDRAM that is able to double the read / write speed of the previous generation of SDRAM memory. There are currently, PC2100 (DDR266), PC2700 (DDR333), PC3200 (DDR400), PC4200 (DDR533) These DIMMs are 184 Pin in size and are not interchangeable with older SDRAM modules.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 29, 2010 | Dell Inspiron 1525 Notebook
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
256 MB DIMM#1(DDR333) UPGRADE TO 2GB RAM in compaq nx6110 pc notebook
You should be able to upgrade to 2 gig. Here are specs. Good Luck.
512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
  • RAM configuration features 2 x 256 MB
  • Nov 20, 2009 | HP Compaq nx6110 Notebook
    He,Hi This is Abhishek from India.I wanna 2 attach an external RAM of 512MB.Will it support or not?
    Hi Abhishek, not sure what you mean by "external" RAM? If you have Vista then you can use a USB drive as extra RAM using "ReadyBoost" - see link (it is Wikipedia so info could be wrong):
    http://en.wikipedia.org/wiki/Readyboost
    If you are looking to add additional RAM to your motherboard then the Aspire 3000 will take up to 2GB of DDR333 (2x1GB modules). See link to manual here:
    http://www.acer.com.au/acer/service.do;jsessionid=32EF97E2669CCE30553D1F1544312AAA.public_a_14b?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3112&sp=page15e&ctx2.c2att1=92&miu10ekcond13.attN2B2F2EEF=3112&CountryISOCtxParam=AU&ctx1.att21k=1&CRC=3559666452
    Sep 12, 2009 | Acer Aspire 3000 Notebook
    Dell Demension 4600 motherboard memory
    From the Dell specifications page for Dimension 4600:
    Memory
    Architecture
    Dual Channel DDR SDRAM
    Memory connectors
    Four
    Memory capacities
    128-, 256-, 512-MB or 1-GB
    Minimum memory
    128-MB DDR SDRAM
    NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
    Maximum memory
    4 GB
    Memory type
    PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
    (non-ECC)
    Mar 09, 2009 | Dell (2336V) Motherboard
    Which memory ram for amilo pro v7010
    http://www.fujitsu-siemens.ru/Resources/123/2080773523.pdf
    Here's a link to the Data Sheet with the specifications to that Laptop in Adobe Reader format.
    Looks like your Laptop came with either 256 or 512 MB of DDR SDRAM and it is upgradable to 2 GB of DDR SDRAM.
    You can check to see exactly how much RAM your computer came with by going to Control Panel, double-click System and it should tell you how much RAM you currently have in the System Properties box.
    The motherboard has 2 slots for RAM, you you could add a second 256 MB or a second 512 MB stick of RAM. Or if you wanted to upgrade to the 2GB of maximum RAM this computer handles, then you can take out the RAM chip(s) that is installed and install two 1G DDR SDRAM.
    Jan 31, 2009 | Computers & Internet
    RAM cuantity
    The motherboard you mentioned supports DDR1 RAM.
    For windows xp and general application 512 MB is enough.
    But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
    Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    I want to know if SDRAM and [email protected] are the same thing?
    No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
    Aug 17, 2008 | Computers & Internet
    P4vmm2 motherboard
    you can add up to 2 gb RAM using either 2 x 184 Pin DIMMs or 2 x 168 Pin SDRAM DIMMs. However that MB does support pc400. The supported RAM speeds are 100, 133, 200, and 266 MHz
    You can buy a pair of Kingston 256 MB DDR SDRAM PC2100 (266 MHz) from the kingston website for under $50
    part no: KVR266X64C25/256
    Kingston is a well known and respected manufacturer of memory.
    Dec 15, 2007 | EliteGroup P4VMM2 Motherboard
    Dell Dimension 3100 PC Desktop Logo
    208 people viewed this question
    Lee Hodgson
    Lee Hodgson
    Ekse
    efs_perpends
    efs_perpends
