Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
Cooker keeps tripping the electricity supply.
When the ovens have been on for any length of time there is a smokey smell from the cooker and the RCD at the consumer unit trips. Turning the cooker on after this continues tripping the RCD until the cooker is allowed to cool down. Even with the live supply disconnected the problem persists. Have tried to locate anything burnt or neutral earth fault but have had no luck as yet.
Any solution would be welcome.
thanks
Posted by matt123 on
  • Anonymous Nov 09, 2008
    my cooker is shorting out
Barry Coates
  • Belling Master
  • 3,463 Answers
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Posted on Dec 15, 2008
Why does the cooker keep tripping the electric power?
loose wire,shorted switch?(You will receive an answer like this if,you did not include the make or model or serial number or
date of manufacture or complete problem and what needs to be done.)
Jun 08, 2015 | Ovens
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 | Ovens
Tripping rcd out
you cannot
The RCD unit works on an imbalance between active , neutral and the ground wire
the problem can be as simple as a moist connection, insect across terminals , wet dust , grease
the test is done by an accredited electrician using a correct meter to check insulation, wiring installation , elements and controls
you have done your best , now it is time to get it done safely
Nov 04, 2017 | Smeg Ovens
Why does my Candy oven Model FPP 406/1x trip the RCD in my fuse box after 3 minits warming up?
as an appliance engineer sometimes the oven element can be at fault, although this always the case, it could be the thermostat also as they are both interplay when the oven is heating up, they could both be tripping the RCD as the earth is detecting that electricity is becoming live due to a component leaking electricity.
you could try replacing both of them with caution (turning the electricity off in the house ect.. using safety equipment)
a good site to use for those components is the following;
Spare Parts Accessories for Electrical Appliances QuickSpares
usually if they don't have the item in stock on the website you can use the contact option and they usually respond pretty quickly and let you know if they can get the item ( most likely )
Apr 19, 2013 | Ovens
Neff double oven trips rcd when either oven is turned on
your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
Nov 03, 2012 | Neff U1421 Double circotherm Electric Oven
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Since we had a new consumer unit with trip switches fitted with 100DP isolator and 30mA RCD, our Smeg 90cm Duel fuel cooker trips it when the main oven is on. The top oven and grill work fine, but as soon...
Someone should check the current draw by the appliance. Then compare it with the name plate to determine if the problem is with the appliance or external power supply.
May 06, 2008 | Heating & Cooling
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
1,604 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Vernon Taylor
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
