SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
SOURCE: faux men's rolex date just
An authentic Rolex will have a screw down back with exactly 144 small teeth. You can only open a Rolex case with a special Rolex tool (Key). We use the Bergeon hand wrench to open Rolex cases. Supplied with 6 Bergeon grooved chucks(18.50, 20.20, 22.50, 26.50, 28.30 and 29.50 mm), these are the same chuck used in the Bergeon 5700RO and will fit in the Bergeon Bit Adpater for 5700-Z Case Opener our number FB-231. Replacement chucks and replacement handle are available in case you have a set that is missing a piece. As is the case with any fine mechanical instrument, special tools are required in order to properly service and adjust a precision instrument such as a fine timepiece. If you are not experienced, it is better to leave this to a Certified Rolex tech. If you do feel you want to proceed, this tool will set you back about $140.00 or so. Just as the internal parts of the Rolex are exact, so is the watch case that protect the valuable watch movement. These tools are used to open the Rolex case without causing expensive damage. You can call Bob Frei at 510-832-0355 ext. 2 from 11 AM to 5 PM Pacific Time Zone, to order one if you wish, or several other sellers of these fine tools can be found by doing a little research on the net. Hope this has helped you.
SOURCE: Diesel DZ1047 watch - need to replace strap
use a pocket knife and put the blade in the grove in between the strap and the steel of the case and pull towards the leather of the strap the pins are sping loaded and work simular to a miniature shower rods very simple so dont get nerves bout it if all else fails you can even just destroy them geting them out and get new pins and straps at wallmart for like 5 bucks
SOURCE: I need a replacement strap
Log in to Nike website and click support button. You should be able to ask them how to obtain the part you are after.
Testimonial: "Thanks"
SOURCE: I have a 18k gents
The incabloc movement is not too expensive but it sounds like your watch is! I am not sure the movements are available for the older watches anymore, your watch will need the right measurements, so if you take it to a watchmaker they have many older parts and may have a watch movement to fit it! The picture in my profile is of a very expensive 6 ounce gold ladies watch with an incabloc movement. The watch was thought to be from Europe somewhere , it was sold for its beauty and the movement itself did not work! Hope this helps explain your problem a little better! thank you!
