Sharp ar 5320 error code f2
I just replaced the drum on a sharp ar 5320 when i put the drum unit and the deff tank in and switched on the machine the copier gave me a code f2 when u press the start button 04 is displayed what can i do to fix this problem
Posted by aksd2028 on
  • aksd2028 Nov 27, 2007
    okay another thing that i want to ask is one of my clients just purchased a epson lx 300 dot matrix printer from me they use 3ply paper in the machine what happens is when u are finnished printing the document and the printer moves it into the possition for u to tear of the papper james at the feeding area now i have changed rollers checked gears almost everything but it still gives me problems
  • santosh_dwvd Dec 21, 2009
    Dear sir.
    I have a sharp copier machine AR-5320 when i switched on it shows U2 .Please help me ;
    santosh dwivedi
Anonymous
Dear sir.
With beast regards
sayed Masood Osmani
Posted on Mar 10, 2009
Anonymous
Yes the new cartridges do not fix worth a darn. We kept getting a Blinking CH. First we cut off one of the bigger tangs in the back as it is not shaped a little different than the older one. That got rid of the Blinking CH...but then we got the F2. Swaping the plug in sensor at first did not work..but tried again and it worked.
Posted on Jul 01, 2008
yousef mokhtar
    Problem Solver:
  • 13 Answers
I have practised the same error before after replacing a new toner cart. we noted that there a slight difference bet ween versions of cartridges , pls note that on the rear side of the toner cartridge there is a plug in sensor tied with 2 screws . tyr to replace it with the one on the previous cart. i did that before twice and it will do . the f2 disappears . pls try the same and if lucky, let me know, with best regards
Posted on Nov 24, 2007
  • nche francis
    nche francis Dec 02, 2013
    has just worked for me right now
Anonymous
    Problem Solver:
  • 9 Answers
Screwdriver is correct with his diagnosis. It's not recognizing the correct cartridge.
Posted on Nov 25, 2007
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
After installation my sharp ar-m420u copier mx-2300g displays error codes L1-00 and F2-00
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Jan 11, 2011 | Sharp AR-5320 Black and White Copier
Sharp ar 5520 fault code f2subcode 40
F2 40 = ATC sensor abnormality
Check e remedy :
Remove/Install the toner cartridge again.
Replace the toner cartridge with a normal one.
Sep 06, 2010 | Sharp AR-5320 Black and White Copier
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
MY AR 5320 IS SHOEING F2
it must have a sub code, F2 sub 40 means you have a wrong toner cartridge, sometimes F2 is caused by lose or broken harness in scanning section, in this case it sometimes display an E7 code.
Jun 24, 2009 | OCE 3140 Copier
Sharp ar 5320 foud code F 7
Hello sir;E7 that' means this machine laser unit have problem, remove it send it to shop for repair.
May 14, 2009 | Sharp AR-5320 Black and White Copier
Error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
1,863 people viewed this question
Ekse
Marvin
Marvin
