Question about Packard Bell Computers & Internet
SOURCE: NEED TO DOWNLOAD CD ROM DRIVER FOR MY PACKARD BELL IPOWER 5264 LAPTOP
Hey there SHAMESTAR, Not an easy find, but here is the location:
http://support.packardbell.com/global/item/index.php?m=home&pn=P730012001
If the link doesn't work, just copy and paste. Good Luck. Let me know if you have any problems!
Posted on Feb 04, 2008
SOURCE: packard bell easynote L4
I found a PDF document that's a service manual for an Easynote H3. It takes you to the point of removing the motherboard. I know it's a different model, but maybe it's close enough. If you want me to email it to you, send me an email at [email protected]. It's a 1.3-MB file.
There are a lot of steps involved. I would recommend using a multicompartmented tray to hold the removed hardware. Be aware that some notebook ribbon cable sockets release the cable after you lift up on the outer shroud slightly.
If you do this job, look at the solder points first. If they look solderable, FIRST epoxy the power socket to the motherboard. When the epoxy has fully set, THEN resolder the joints. Use a low-wattage iron, not a gun.
I look at it this way: You can't make it work any less, and if you succeed, you'll be proud, and will have saved a lot of money.
Posted on Apr 11, 2008
SOURCE: packard Bell Easynote E4 - Wireless Switch
i've been having the exact same yrouble with my Easynote E4 laptop and have just fixed it.
in the bottom left hand corner of the keyboard theres a key with Fn written in blue, hold this down and press F1it should beep and the 'wireless lan connection indicator' in your system tray the red cross will disipear then you will pick up wireless!
Posted on Apr 26, 2009
SOURCE: opening a packard bell imedia case
there are probably a couple screws on the back to undo then it slides of or
look under front f case on slightly older ones pre 2000 cases
they have screws under front face plate there is a little hole there put your habd in there and yank it off
you wont damage it there usually stiff
Posted on Sep 19, 2009
General specs for Packard Bell two-in-one 10-inch tablet are
"10.1 HD IPS display 1280 x 800
Android 8.1 Oreo go Edition
64-bit quad-core processor
1 GB Ram
16GB internal storage expandable with SD card.
Dual Band Wi-Fi
Detachable keyboard with trackpad"
call or contact PB, and ask for support.
Packard Bell (160248-01) Computer Speakers with a 12
volt power source worked OK,
Tried a 9 volt and it also worked.
This pair of speakers is grey with a
barrel design. The mounting surface placed flat is approximately 10.25
inches by 3.75 inches. Each end has a rainbow design with a depth of 2.75
inches. By placing with the mounting surface flat on your desk gives you an out
of the floor design. The front edge from the desk to the bottom edge is 1.5
from the surface to the top edge with a 3.75 inch. Suggesting you may mount
them under your desk, on the side by your legs or stand them on each side of
your screen.
I am told they come in white and black also I found them rather large for what I need but your decision is you should be happy before buying a pair.
