Question about Makita Saws
Makita 2012 planer, bought in 1990. a 12 inch board comes out thicker on one edge than the other by about 1/32 inch; maybe 1/16" is there a way to fix this? thanks
Cannot adjust with in and out feed tables. need to level center section under cutter head
Posted by Greg Laplante on
Bill Boyd
    Top Expert:
  • Makita Master
  • 53,816 Answers
The cutter roll/blade is not parallel to the cutting deck so one end needs adjustment
it could be from the cutters being blunt at one end and that will produce extra pressure at the other end or is not cutting as efficiently as the other end resulting in the problem
Posted on Aug 05, 2017
1 Related Answer
Anonymous
  • 12 Answers
SOURCE: delta rockwell 22-200 planer. I need a manual.
Check on www.owwm.com. You will probably find your machine on their and resources to help you in your quest. It's a great site for old tool hounds.
Posted on Jan 16, 2010
How do you adjust the replacement blades in a Makita planer if you don't have to original gauge?
The blades, at thier highest point in rotation, need to be exactly the same height as the larger back plate. Any straight edge laid on the back plate and extending over the blades will let you know if they are set properly. The straight edge should not contact the blades when they are turned (by hand) and there should be as close to no gap between the straight edge and blades as you can get.
2answers
I picked up a Maketa 12" Planer Model 2012 at a
Got it, go to "makitausa.com" and on the right side top type in your model number in their search box, follow the links to the page where you can download the manual or a parts breakdown. The manual is 20 pages long. Let me know if you need more assistance
1helpful
I need instructions on how to replace a new set of power planer blades for Makita 3 1/4 inch power planer
find your model number and go to "makitause.com" and you can download the operators manual with detailed instructions for this repair. REMEMBER to unplug tool before starting. If you give me the model number I will help but they had 2 different types of holders on the planers so I can't begin to help. Let me know.
How do I put on the drive belt for a makita planer 2012? It appears to be 1/4 too short to fit over the small wheel.
Usually, the motor position is adjustable by loosening the mounting bolts. Once the belt is on, snug the motor until the belt has about 3/4 inch up/down movement midway between the two pulleys. Hope this helps!
Were can i buy a drive belt for a 1902 makita hand planer
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/1902
I've had really good luck with Tool Parts Direct. They send emails when something ships and are upfront about the parts they order direct from the manufacturer.
Part Number 225071-8 is $10.79 and ships in 10-14 business days.
How do you install drive belt on makita model 2012 planer
you roll it on, start belt on bigger pulley and then just turn pulley by hand and gently start it onto the smaller one. UNPLUG tool first though
Saws Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
