What do i do, i have tried everything to get the cd out but nothing is working. it doesn't show an error message or anything. everything else works fine just not the cd player.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
My car radio and cd plays but the cd won't eject
SOURCE: cd player doesn't play or
The CD is probably not in the carousel the way it should be and cannot play and also has the door jammed so it can't eject. Sometimes this can be fixed by taking a thin object like a credit card and sliding in between the top of the door and the case. If you can move the CD just a little, you may be able to get it to eject.
SOURCE: cd player code and ac
E01 means disc changer malfunction which usually means the cd is not inserted in the disc magazine
