SOURCE: PROBLEM WITH SAMSUNG DLP TV
disconnect the power and hold in the power button for 30 seconds to reset it.
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
SOURCE: Magnavox Projection DLP HDTV
I had the same problem...I took the back panel off the tv and took a small desk fan and mounted it so it would keep the bulb extra cool...IT WORKED! I left it like this for about a week. It shut off only twice after about 4 hours of on time. I then disconected the small white ceramic sensor on the back side of the light. (there is a plug conecting it, just follow the wire to it) It has been about 3 weeks now and I have not had the tv shut off yet. (disclaimer...could start fire from over heating? try at your own risk.) If it works for you buy a new sensor.
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
