Question about Windchaser Heating & Cooling
SOURCE: one side air/other side ac
I have the same problem. Don't know if the dealer messed it up when they changed the air filter or something else.
Posted on Jun 25, 2008
SOURCE: poetable AC compressor licks in for 10 min
It is probably either the high pressure switch or the frost control. The high temp switch usually trips because the condenser coil is dirty which does not allow it to exhaust heat very well. The frost control will trip if the system gets below 39 degrees on the pipes. This is usually do to low refrigerant or dirty filters. Good Luck!
Posted on Jul 03, 2008
SOURCE: heater blows cold air ac blows warm air
Your problem is the air temp control blend door actuator is defective and not controlling temp u set. to change/access this part the dash assembly must be removed from the car.
Posted on Mar 24, 2009
SOURCE: ac blows warm air onb acceleration
Sounds like throttle A/C cutoff. Check at what point A/C stops. Full throttle, 3/4, half, etc,... You can disable the throttle A/C cutoff. This is designed for increased performance. Check manual for your cars setup.
Posted on Jul 07, 2009
Jan 14, 2018 | Cars & Trucks
Oct 05, 2014 | Windchaser PACR10 Portable Air Conditioner
Aug 24, 2011 | Windchaser PACR10 Portable Air Conditioner
Jul 22, 2011 | Windchaser PACR10 Portable Air Conditioner
Aug 28, 2010 | Windchaser PAC9 Air Conditioner
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Aug 31, 2009 | Alen C475 Portable Air Conditioner
Jul 21, 2009 | Windchaser PACR10 Portable Air Conditioner
Jul 03, 2008 | Maytag Portable Air Conditioner M6P09S2A
Mar 30, 2008 | Windchaser PACR10 Portable Air Conditioner
222 people viewed this question
PACR93S is the model number
