Question about Whirlpool Cooktops
Trying to connect a whirlpool ceran hob to a defy slimline oven but the wiring is different
The defy oven has a connection for two 5 point connections and the ceran hob has one with 3 and one with 4 points
Posted by Les Ballard on
5 Related Answers
gerbee gomez
  • 222 Answers
SOURCE: Installing Smeg Gas Hob PGF75-3 Ultra Low Profile.
yes u can install it at the top of the drawers but check the gas connection before closing the drawers to make sure ther no problem,the inlet gas connection is in rigth side facing to u.
Posted on Dec 02, 2008
Anonymous
SOURCE: Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Posted on Jun 13, 2009
quady
  • 142 Answers
SOURCE: Black hob top cracked in two places and small part
yes but costly.have u tryed home insurance accidental damage.
Posted on Sep 14, 2009
mike kennedy
  • 146 Answers
SOURCE: How do I turn the
find the button that has a lock on it or beside it, push it in and hold it until it unlocks
Posted on Jan 19, 2011
charles urban
  • 436 Answers
SOURCE: fagor induction hob
here is link to installation manual:)
http://www.fagoramerica.com/my_fagor/technical_information
Good luck and BE CAREFUL!!!
Posted on Apr 11, 2011
My soup spilled over on to my whirlpool ceran cooktop and i cant get the stains off. Is there a way to do it?
Is this a ceramic hob? If it is, you will need a ceramic hob cleaner (john lewis does one) OR Astonish oven/pan cleaner, a non-scratch washing-up sponge and a fair amount of elbow grease. This works for me.
Oct 05, 2009 | Whirlpool RCS3014 Electric Cooktop
Sep 14, 2009 | Cooktops
Nov 28, 2008 | Neff T1323 Electric Cooktop
Hotpoint
just a thought - check the connection block where incoming mains connects to the hob. these quite commonly burn out
Sep 07, 2008 | Cooktops
Conecting a lead to an electric hob
the usual method is to link the 3 live terminals together and the 2 neutrals. the links normally come with the hob and are often already in position. make sure the links are present and tightened down. it then doesnt matter which of the three you connect live to and same for neutral
you should connect the double oven on a separate circuit with its own isolator
Jun 23, 2008 | Cooktops
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
Cooktops Logo
161 people viewed this question
Top Whirlpool Cooktops Experts
Michael Thomas
Michael Thomas
Gustavo Ortiz
Gustavo Ortiz
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
