Question about Water Water Heaters
How to fix a code 13 of water heater, Richmond?
Posted by Francisco cereno on
Chad Hummel
I got this from day one. It's not a dirty part. Support have me the run around. Over 100 pictures of the exhaust and intake set up. More pictures at each level of support. After 80 hours of phone time with support I have up. A few months later I got a random person at rheem and he sent flame rods to me. I replaced them and it worked. For about a month. Then 13 again. I've had it apart so many times to check for a blockage because that's what they tell me. I seen a few people claim it's the gas control valve being plugged up and to take it apart to get any debris out. That's the last thing I have yet to try.
Posted on Jul 19, 2020
Brad Spicer
    New Friend:
My outdoor Rheem tankless was flashing a code 13 so I why’ll I was in front of it I pulled the relief valve also known as TMP valve and noticed that after a second or two I smelt gas coming from the vent I am mediately knew that it did not light so I tested the coil and it was not giving any spark so it was not igniting sometimes a code 13 it’s something simple that doesn’t require a lot of looking or testing just simply knowing how the unit works is a big help
Posted on Mar 23, 2019
Gene Haynes
  • Water Master
  • 5,391 Answers
5 Related Answers
clay
  • 74 Answers
SOURCE: water heater not heating it's a richmond water heater
Now change the thermostats........this is the only other thing it could possibly be.
Posted on Apr 27, 2009
Anonymous
  • 248 Answers
SOURCE: I have a richmond tankless water heater and its
1/overheat stat 2/ fan 3/diaphrapm valve 4/ micro switch check area around fan very small hose pipe for pinhole best of luck
Posted on Oct 30, 2009
Anonymous
  • 244 Answers
SOURCE: Paloma tank less water heater flashes code C4 13
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Posted on Nov 17, 2009
Anonymous
  • 11 Answers
SOURCE: richmond water heater, goes into lock out
flame sensor error remove and clean with steel wool or replace but becareful because most of them have the ignitor and flame sensor on one bracket and the ignitor is fragile and most important don't touch it the oils from your skin will cause it to burn out
Posted on Apr 03, 2010
Lickzee
  • 68 Answers
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
I have richmond rmtgh95dv on demand water heater code 13 shows up and i have no hot water how do i fix this ?
Call rheem for the how to on clean and testing the oxygen depletion sensor and check the venting
Jul 02, 2014 | Rheem Paloma Tankless Water Heaters...
I have a richmond takless water heater with codes c8-76 . what is that and how can i fix it?
1) Rheem -Richmond error 76: communication error with remote, bad remote or failed PC board
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Rheem will send PC board and you can replace yourself
3) Add comment and say what you discover.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 08, 2013 | Water Heaters
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
How to repair code 13 for tankless water heater
10-15-2012
Code 13 is probably Rheem, Richmond, Ruud, Paloma etc tankless.
Copy following link for troubleshoot resources:
Error 13 is oxygen depletion sensor
Imperfect combustion.
For example if tankless does not have required maintenance, then burner can get dirty and clogged.
This will cause unburned natural gas to rise inside hot flue pipe causing risk of explosion and fire, or in case of propane gas that is heavier than air, the gas will build up inside combustion chamber and cause explosion and fire.
Oct 15, 2012 | Water Heaters
Richmond tankless water heater will not clear error code
Why is it always Rheem problems?
Every water heater problem at fixya is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Rheem 2012 manual says if error 13 still displays, then contact installer or service technician. Mo Money buddy.
This is about oxygen sensor, poor combustion, bad venting, inadequate air supply, failed sensors, etc.
Get more fresh air to unit and see if that solves problem. The call service technician, and get out wallet.
Copy following link for Rheem-richmond tankless troubleshoot.
Maintain water heater according to instructions in manual to avoid common error codes. Of course this means you have to service the unit each month, and each year, without guarantee the thing will work correctly.
Sep 06, 2012 | Rheem Tankless Hot Water Heater...
Our Richmond Tankless is showing a reading of a C2 error code. How do we fix this. Why is it doing this?
Before calling service technician, open following link for Richmond/Rheem troubleshoot resources including Rheem chat.
Error codes are considered start place for troubleshooting.
C2 11 is 'No ignition' or 'Gas is inadequate' or 'Ignition failure'
Error C implies ignition rod
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Jun 18, 2011 | Rheem Tankless Hot Water Heater...
I have a richmond tankless water heater RMTG-74PVN-2 . the unit works most of the time but code c-2 comes up on the display and the unit shuts down. I shut the power off to reset this does not fix the...
I have a Richmond tankless water heater PTG2-42PVN. It will work for a very short time & then I get an error code of either C4 or C7. The remote control alternately flashes IL - 120
May 16, 2010 | Rheem Tankless Hot Water Heater...
New Richmond tankless water heater C8 error
I think error code C8 is #13
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Sep 01, 2009 | Rheem Tankless Hot Water Heater...
Water Heaters Logo
3,245 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
