Question about Siemens Dryers
Siemens iq500 dryer - how do you remove and clean the air intake filter
Posted by Helen on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: 2000 Gmc Yukon Denali wont start i changed fuel pump and filter
your getting too much air in chamber on igintion probly cause by a faulty intake and or a faulty tps (throttle positioning sensor) sounds like intake is sucking more air that fuel which is giving a bad air fuel mix in chamber also try checking your mass air could be faulty as well
Posted on Feb 10, 2009
Anonymous
  • 87 Answers
SOURCE: Clothes dryer (Kenmore) only blows cold air
What is the model number on the inside by the door. It's most likely a thermal fuse or the element. Do you have a way to check fuses by a meter or something? There are usually 2 thermal fuses on the pipe with big red wires where the element is. Usually they go out if not the element.
Posted on Apr 13, 2009
mahesh patel
  • 197 Answers
SOURCE: TV was shutting off every 30 min.
bad lamp google for part 3
Posted on Jun 09, 2009
Anonymous
  • 310 Answers
SOURCE: how do you remove the engine air intake filter
take the nuts off then pull it will pop out
Posted on Feb 15, 2010
Anonymous
  • 10 Answers
SOURCE: My siemens 750 extraklasse tumble
THE FILTER YOU HAVE IN YOUR DRYER IS PROBABLY TOO FINE
TRY A NEW ONE WITH HIGHER MICRON VALUE
Posted on Oct 01, 2010
How and where does one clean the filter on a defy autodry? I need to check as there is a warning light which i need to check as it does not want to get warm.
https://www.manualslib.com/manual/926961/Defy-Autodry.html?page=7#manual
Quoting:
Cleaning the Lint Filter
The lint filter, which is located behind
the door, should be cleaned after each
load to maintain optimum drying
efficiency.
The filter and filter cover are located
inside the door surround front.
Insert two fingers into the two large holes
and pull the filter cover free of the door.
Remove the filter mesh and clean off all
the lint by gently rubbing the filter mesh.
Replace the filter mesh and then the
cover.
Ensure that the filter is in position before
closing the door.
Cleaning the rear Air Intake Grille
The air intake grille, at the bottom rear of the machine, should be cleaned regularly to
maintain optimum drying performance.
Remove any obstructions and dust the grille off with a soft brush
Defy autodry Owner Manual Unsuitable Materials
Jul 02, 2018 | Dryers
How to unlock siemens model iQ500
Move big dial to the program where you inicially locked it.
The Key icon will stop to blink and stay on.
Then pres start button for 5 seconds and it is unlocked again
Jun 04, 2014 | Cell Phones
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
Dec 21, 2013 | Siemens Dryers
My washing machine is lock & can't be open ... (iQ500)
unplug wait 5mins plug back in it worked for me
Apr 13, 2013 | Siemens Washing Machines
My dryer keeps saying Lint Filter Problems and cutting off however the lint filter is clean. Because of this issue I the dryer will not stay on long enough to actually dry the clothes. It continuously...
try two things. first, run it empty without the lint filter installed. if it gives you the same error message, install the filter, but disconnect the flexible duct connected to the back of the dryer. try it again. if it still wont work, you will have to get it serviced and cleaned out. if it works with the ducting removed from the back, your dryer duct is clogged up. check your yellow pages for dryer duct cleaning. The lint filter error message is just your machines way of saying it is not getting enough air flow. It can be caused by a clogged duct also.
Nov 20, 2010 | Siemens Dryers
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Dryers Logo
146 people viewed this question
Top Siemens Dryers Experts
Lee Hodgson
Lee Hodgson
Mike
Dan Woods
Dan Woods
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
